It is rare that it is a coolant problem, in the SHO at that mileage anyway. The cats treat the exhaust stream, and unavoidably, mask what is going on in the engine. Most commonly it is a puff of blue rather than white smoke,, but the issue, some say, is a question of sufficient backpressure to maintain turbo seal integrity. IDK. Do you have access to a shop that can check the backpressures for you? May want to check the piping at the turbos periodically as preventive maintenance.
