74k on the vehicle. In for an oil change and noticed the FRONT turbo is seeping oil down onto the front frame and to the front tranny mount, under the bell housing. It must be rather small, overall, as I don't notice an appreciable oil loss on the dip stick - half a quart in 5,000 miles.
I do notice the vehicle almost misses/has a lope to it's idle when cold. It also chugs a bit - like a 70's muscle car, when it's cold. Otherwise, power it there and there is only a slight bit of gray smoke coming out the rear pipes on WOT.
I've read about the leaking banjo bolt/seal - perhaps that's all it is? It goes in Tuesday to check it out more closely.
Any thoughts/words of wisdom to look out for?
Thanks,
Shumax
