170° thermostats & 3 bar map sensor
Started by mcrmb1, April 22, 2017, 08:08:53 PM
mcrmb1
Whats the best brand for a 170° thermostats & 3 bar map sensor and what should i pay. Do i have to have a tune before i install them???
2010 Ford Flex Limited 3.5L Eco-boost Upgraded Timing and water pump to 2012 version
Quote from: mcrmb1 on April 22, 2017, 08:08:53 PM
Don't know about the thermostats but you are best served to get the ford MAP sensor. It's the easiest to scale in the software.
You actually are getting the TIP sensor that is pre throttle body...SO essentially you are running 2 identical sensors but the MAP sensor is replaced with a stock TIP sensor. So you can make sure you are getting the right sensor just check that it is the same as the TIP sensor that is between the intercooler and throttle body.
And yes you need to have a tune to run that sensor....Funny thing is you can probably flip flop the 2 sensors and get a tune the correct way and not even have to buy the extra TIP sensor and avoid being upcharged.
I personally have the Reische 170- stat for over three years now and definitely a quality piece for sure and just add a tune for the added benefits.  Z
http://www.lethalperformance.com/reische-performance-ford-4d-170-performance-thermostat.html
63.00-free shipping
I think they make the Reische now in the US, instead of Germany.  It is a modified Stant thermostat.
jonnoriega
Quote from: AJP turbo on April 22, 2017, 09:55:41 PM
I just bought a Bar Map Sensor along with a Ford Explorer Sport Level 3 Performance Pack from Livernois Friday.  It wasn't cheap but it's the same set up as a friend of mine who has a XSport and his is fast.
The Performance Pack comes with a set of down-pipes, Windstorm CAI, Tune, Spark Plugs and a Thermostat.  I can't wait to get it all installed!!!
2016 Explorer Platinum
Looking forward to your narrative, jon!
