What elevation do you live at?
I noticed you have a 2012 F150!! Did you ever have your intercooler checked out in form of an updated TSB followed by a reflash of the PCM.? ZI would also check your boost solenoid and waste-gate hoses to make sure the hoses are not loose or split.Any DTC codes set ? How many miles on her?DSMtuned due setup an intro by following the below link and Welcome,thanks. Z http://www.ecoboostperformanceforum.com/index.php/board,14.0.html
1) BOV solenoids (one or both) are failing. 2012 F-150 here, so mechanical BOVs.2) Wastegate solenoid is failing. You can see the WG percentage sometimes falls when the boost falls, but not always, so I'm thinking the sharp increase is more of a compensation.3) Wastegates are mechanically being blown open due to weak springs and the decreased backpressure with the new high flow downpipe made this worse.I still can't put my finger on why the throttle angle would change with the oscillation of boost like it does.
Quote from: DSMtuned on April 15, 2017, 08:43:33 PM1) BOV solenoids (one or both) are failing. 2012 F-150 here, so mechanical BOVs.2) Wastegate solenoid is failing. You can see the WG percentage sometimes falls when the boost falls, but not always, so I'm thinking the sharp increase is more of a compensation.3) Wastegates are mechanically being blown open due to weak springs and the decreased backpressure with the new high flow downpipe made this worse.I still can't put my finger on why the throttle angle would change with the oscillation of boost like it does. I don't think your BOV's are mechanical. Everything is electronically controlled at some point with these. The downpipes shouldn't have made that dramatic effect on back pressure to the point it would manifest itself in other ways.You really need to throw out conventional wisdom with the engine management with ecoboost. The throttle will do what it needs to in order to achieve the boost that is being commanded. Have you logged "desired TIP"?The throttle pedal and throttle blade relationship really mean nothing that you think it does anymore....Your pedal position is simply a torque request and then gets processed in a complex algorithm which gets turned into an airflow request which then gets turned into a TIP(throttle inlet pressure) and the throttle will do what it wants to maintain the same TIP in the intake manifold.I also think your elevation is playing a factor
Quote from: AJP turbo on April 14, 2017, 01:11:18 AMWhat elevation do you live at?I'm at 6300'. I asked 5 Star to correct for altitude
Did you have 5 star review the logs?
