Quote from: AJP turbo on April 21, 2017, 08:41:51 AMWould you like to try a test tune?Do it do it do it
I fear you are now starting to throw money at parts without proper justification....i thought you posted a log where desired tip is fluctuating....if thats the case then its likely not a hardware problem....something is telling the hardware to act a certain way
Curious, have you tried to return the truck to the stock tune and see if the issue persists?
You really need to return to stock like mentioned by sho boatIts really the first step in troubleshooting an issue with a tuned truck....you blindy already threw money at the truck already You need to isolate and rule things out when possible and returning to stock achieves that
