PUP is not the same as Pennzoil Ultra, just to be clear. BUT again, the key is OCI. Don't expect it to run to the same intervals as Amsoil Signature, that is the most important note. At least Amsoil specifies intervals for both normal & severe duty! So if we take the stated OCI for any other oil cut it to 40% for severe duty, that might be a good yardstick as well. I only suggest that because Blackstone data is so hard to come by.
If you are going to track the car regulary, your OCI should be on a severe duty interval at the very least. And, yes, there are some owners who will change the oil and trans fluid after every track day, and the results speak for themselves.
