High elevation times. 4000+ft post em!
Started by Vortech347, August 17, 2016, 01:29:37 PM
Vortech347
So, I took my SHO to the track and ran it two weeks ago, but I'm curious as to what others have ran in higher elevations as well.  I'm in Utah which is 4300ft and our air density is usually between 7000(good day) 7600(Crap day)
I don't have a stock benchmark, our track is flooded with 16-17 second fart cannons so runs are limited. I typically only get 3-4 passes.
Mine 13' PP with K&N panel and Unleashed 3 bar 91 tune.
Best ET, 13.53@99 (95* ambient air)
Best MPH 13.62@104 (Botched the launch because it pushed through the brakes, it was also 1am so max cold air 71* ambient)
Both runs were either low 1.9x or high 1.9x 60'
Matt H.
2017 F150 XLT 5.0
Brucelinc
I have never run in that DA but the DA calculator will give you an idea of what it would run in better air.
Density Altitude:
7018
feet above sea level
1/4 mile ET:
13.53
seconds
1/4 mile trap speed:
99
MPH
Correct ET and MPH
Stock and Mildly Modified Naturally Aspirated Engines
12.336 @ 108.341 MPH
Extensively Modified Naturally Aspirated Engines
12.591 @ 106.009 MPH
Extensively Modified Supercharged and Turbocharged Engines
13.013 @ 102.792 MPH
Read more: http://www.dragtimes.com/da-density-altitude-calculator.php?elevationcorrect=7018&et=13.53&mph=99&correctetmph=Correct+ET+and+MPH#ixzz4HgtfpXHj
Colorado-SHOBro
a buddies bone stock14' SHO PP ran a 13.8 at bandimere speedway up here in denver. altitude 5800,DAs range from 7500-9000+. tune only SHOs are running 13.5's give or take a couple tics here. tune and exhaust SHOs low 13s. I'd say you may be leaving a little power on the table with those times but not a whole lot.
altitude hurts but hey . . at least your not NA right!
12.8@108 @ 6,000ft DA.
Vortech347
Quote from: 8nutz8 on August 21, 2016, 06:49:51 PM
This is exactly what I wanted to know, fellow CO folks.  You guys get stuck with the same crap we do.
Matt H.
2017 F150 XLT 5.0
Boosted150
#4
Bandimere speedway 8400 DA that day. 2015 f150 3.5 supercab full tank full weight 4wd launched. Mpt 91 tune only. Truck 969 left lane. I also tried 2wd and ran 14.9 zero traction
2015 f150 Supercab Fx4. MPT Tuned, AEM drop in, 170 Reische thermostat.
