As long as you keep the car temps reasonable, I don't see the need for running thicker oil. These are not 100% aircooled machines, so you have SOME control over those conditions. If you live in an area where the startup temp is going to be 120F, or -50F, modify the requirements for the LOW end of the spec to suit (for example, 10W30 or 0W30 instead of OEM 5W30). That's been the usual tactic. NOW, if you are adjusting for engine wear, you have a reason to go up the grade on the HIGH side of the spec (for example, 5W40 or 5W20 instead of OEM 5W30).
All this keeping in mind the VI, the Noack, etc.
