Knock with stock tune at WOT.
Started by curry67, August 01, 2015, 05:11:43 PM
AJP turbo
Quote from: curry67 on August 02, 2015, 02:31:30 PM
So would thst explain higher knock readings on higher octane?
Sent from my SM-N910W8 using Tapatalk
Maybe....But you really need to have someone verify on a log just to make sure that's really what you have. Then I would want to look for trends....5 and 6 is a little high...If it's an isolated event then no biggie. If it continues then your timing tables need work and are over advanced and you are relying on the knock sensors.
Take your device and under user options  retard the spark by 4 or 6 degrees and see if it's better...If it is then your spark tables are over advanced.
I like my knock sensor readings to be like my short term fuel trims.....They should hover around 0. A little above and below is good.
SCT Dealer/Custom Calibrator
Specializing in 3.5 Ecoboost
Former:2014 PP SHO
405whp/520tq
Dyno
Tuning in progress
curry67
Quote from: ajpturbo on August 02, 2015, 02:39:21 PM
Even on stock tune?
AJP turbo
Log please..
Well it could've been isolated...Isolated could even mean a weekend or how long you had some fuel or how long a station had that fuel I dunno....
Seems like some of you folks from canadia land battle fuel troubles now and again eh?....And those cooler temps up there may lead to extra spark advance due to the IAT compensation tables...As IAT's are cooler the ECU will add some timing also
Former:2014 PP SHO
405whp/520tq
Dyno
Tuning in progress
Quote from: curry67 on August 02, 2015, 02:42:24 PM
Even on stock tune?
X2 on that ?
curry67
Got a log with 6 wot pulls upload it when I get home
That is one gargantuan log file, curry!  Working on it now.
AJP turbo
Your Wot pulls are very short. Good data goes along way when logging....can be tough on the street though...I have my good secret places to log where I live.
Your not really giving the car time to settle into a nice pull. I did see one of the WOT pulls though where there was no knock sensor readings. Even though you had some knock sensor readings your timing did not look overly advanced. I saw spark around 13-16 degrees so that's fine....But you did have more knock sensor activity than I would expect to see on a stock tune. I wouldn't be worried but I would watch for trends and see if it continues.
Try and get a nice long pull if you can. at least 2 or 3 complete gears or 80 mph of acceleration. Give it time to pull and see how it looks and if the entire pull has knock sensor readings.
Some have had to do the knock sensor wire mod. I have my doubts on if that does anything but some say it helped them. These ECU's are so busy and dependent on environmental conditions I can see coincidence and timing of the wire mod playing a factor. I can't see vibration and noise appearing as high knock readings....Why not low? And if the wire is so bad it was grounding out on people then the knock sensor PID would just flatline I would guess. But I have seen what people call false knock or ghost knock as reported from knock sensor due to aftermarket cams that have noisy valve trains or metallic noises from exhausts having an effect.
You should try and flash and pull 6 degrees  or some dramatic amount like 10 to see if it's the tune...If it's not then you have a component or sensor failure maybe
That's what I see at this point...Does't look real bad though...Let the sensor do it's job..Or wait for a DTC....If you don't have a dtc it can't be that bad...This car basically has the ability to tell you if your farts contaminated your alcantara in the seats
Former:2014 PP SHO
405whp/520tq
Dyno
Tuning in progress
I do see timing being retarded even at single-digit speeds, not just WOT.  All in 1st gear, seems the banks are not sync'd for some time before & after the timing is retarded.  In decel, after 3-1 downshift.
Assuming stock tune still.
curry67
ya all stock tune. I gotta try to find a spot i guess probably have to drive outside the city.
Highway on ramps are always a good spot....
Make a note of any rattles or ticking noises you hear at any time.  Want to eliminate cam phaser/timing chain involvement.  What motor oil/filter are you running, BTW?
curry67
#42
i managed to get 2 decent pulls 1 good launch but i noticed one of the afr values goes to 0 for a bit seemed interesting. timed my 0 to 60 at 6 flat which isnt to great but i guess its a non pp and stock. also im 310 lol.
https://drive.google.com/file/d/0BzPC7uX6FB_AX3hvX3ZhRkE3dDg/view?usp=sharing
curry67
Quote from: SHOdded on August 02, 2015, 11:52:22 PM
Motorcraft filter with Motorcraft full synthetic. dont really hear much while driving feels pretty smooth.
AJP turbo
Your bank 2 primary o2 sensor seems to have checked out....I don't know what that's all about...I would replace it....What's up with all the bad 02 sensors lately?...At one point it was reading 1.0 when the bank 1 sensor appeared to be reading normal....Then I saw it reading 0. That can't be good
Former:2014 PP SHO
405whp/520tq
Dyno
Tuning in progress
