Make a note of as many details during the occurences as possible: what gear you were in, what were the rpm's, did the load change, how much advance, etc. Like aj says, probably perfectly normal, but since we like dig into things here, why not?
Sometimes sensors have a brain fart or valves don't open/close at the precise moment they are expected to. I assume the knock sensor wiring has been checked and/or taped off? BTW, at least in some people's experience, even Mobil 1 may not be the best fuel for your area. So try changing brands (always use a high-volume station, preferably top tier) and see if that makes any difference. Run some Techron or BG44 through the gas tank (doesn't hurt, may help).
