Incorrect AFR at WOT Help!!
Started by kskrew4life, July 26, 2015, 08:59:14 PM
curry67
i have seem to be having problems with my o2 sensors aswell but i also have a knock issue so seeing your logs with 0 a max makes me depressed lol
Datalogging, great for pinpointing issues gone wrong.
Rich
Quote from: curry67 on August 07, 2015, 08:47:05 PM
Fix your O2 sensor and go from there...these systems are so complex and dependent of other things u could have a multitude of things going on...for instance there are spark and fuel modifiers for lengths of time spent at various afr's....so if the afr is at a certain amount for so long it may see fit to modify spark or fuel. These compensations will be on top of base tables......fix the sensor as I thought we identified that issue at least earlier....I'm losing track..can remember if that was u or brewer
curry67
Got some new fuel from different top tier brand knock as high as 7 now. The afr2 went to 0 a few times bit otherwise it appears to be working.
Sent from my SM-N910W8 using Tapatalk
Quote from: curry67 on August 07, 2015, 10:56:55 PM
My AFRs randomly go to zero and both cars behaved the same.
curry67
Quote from: FoMoCoSHO on August 07, 2015, 11:15:30 PM
so it going to 0 randomly for a few seconds is ok?
Sometimes data stream can get disrupted  and you will see 0 for a split second but it shouldn't happen very often....So if it went to 0 a few times then I don't know if I would say It appears to be working ....Doesn't sound good...I forget, did I look at one of your logs?
Just saw your new post....But NO! a few seconds is not ok....A tiny blip is the data stream being lost
Quote from: ajpturbo on August 07, 2015, 11:26:05 PM
AJP's explanation is what I have experienced running Torque, Dashcommand, OBDLink, etc......
Quote from: FoMoCoSHO on August 07, 2015, 11:30:33 PM
My old mustang was terrible, I think because of the cave man processor..The more items you log the worse it is. SOme PID's take more memory or something like that....I think its like bandwidth...SOme PID's require a lot of it...Or sampling rate I dunno....I notice better quality logs when I reduced the amount of paramters I log
curry67
Cave man sensor lol?
cave man processor in the older ECU's
ecoboostsho
Quote from: ajpturbo on August 07, 2015, 11:44:57 PM
You would be correct. Certain PIDs do indeed return more information (multiple bytes) where as others simply don't need the resolution and use less bits...
kskrew4life
Has anyone else notice 5+ kr at cruising speed while on cruise control? under WOT kr is -4 to =1 (which is normal) odd that im seeing knock at cruising since not altof load is on the engine
