Turbo 'flutter' during low rpm / high gear acceleration...
Started by zzfb, July 04, 2015, 01:28:26 PM
John Miller
Good info - I will certainly find out :)
2015 Taurus SHO, Non-PP, 93 Octane Livernois V10 "Soft Shift" Tune with 170 Reische Thermostat and 3-bar MAP sensor
Quote from: John Miller on April 21, 2016, 07:34:21 PM
I dont think you will be able to....scalar descriptions are hard to come by...im telling you what is in the tune...there is a seperate section for cruise control...no shift tables there
John Miller
I meant I will use the cruise control and find out if the updated shift parameters, already experienced during normal driving, also apply with the cruise on :).
Torrie did mention that there are two shift tables labeled CR2 and CR3.
John Miller
I know I said I would report in a week, but my first commute impression:
The last revision got the 1-2 shift from the "wheel hop" feel down to a hard "bang" shift. After one commute in, the adaptive leaning has done the rest ... all shifts are now smooth and just firm enough. Not even the bang feel. Perfect.
As for the flutter at hand, the quicker downshift seems to be an answer. Under almost all the conditions I could previously replicate the flutter, the car will go to 5th before it can happen.
I say "almost" cause, if I try really, really hard on just the right incline, I can ease into the throttle just enough around 65 mph to get it fluttering. But, I really have to get it perfect and I don't think it is something that would happen during normal driving. Probably will end up 95% fixed and a good compromise, as I would hate it to gear down too quick.  And, I think I've worn out my revision grace with Torrie :)
Didn't try cruise today, as I still want to get a feel for the car in its new state.
Glad to hear the situation is solved...by the way, I know guys that are on over 50 revisions with Torrie...quite a few actually. You have plenty of those revisions left just so you know.
John Miller
Thanks. I don't know it is "solved," but will know more after 5 or 10 more commutes.
I think it is possible that it is downshifting perfectly at most speeds but that there is a small window where it just needs to downshift a hair faster.  I'm not married to that idea though - I need to drive it more.
According to Torrie, the downshift calculation is a function of output shaft speed to throttle position. So, if I do find a window in MPH that needs adjustment, I'll need to data log to find the OSS and actual throttle angle for him.
Quote from: John Miller on April 23, 2016, 08:35:03 AM
Keeping in mind that much as we like accuracy, electromechanical interaction means there will be a range you'd need to work with, rather than a fixed point set in stone.  For example, you may be seeing a decay in sensor function over time that forces periodic tune adjustment.  May not be in the best interests of longevity either
That said, def looking forward to seeing how much fine control we have over the SHO :)
Glad to see some progress in the right Direction.  Z   :)
Excalibur
It's been a week with my final revision from my tune from Torrie and I have noticed mine doing the same thing. checked all the hardware checks stated earlier, so I'm guessing I'm going to have to email Torrie as well and see if it will fix mine. I'll report back after I find out something. great thread btw.
2013 PP SHO; k&n drop-in, 3bar, unleashed tune.
John Miller
It's going to take some trial and error.
I confirmed this afternoon that it must use different shift tables when you activate the cruise control - my early downshift disappears with cruise activated.
I'm still going to give it some time - I want to confirm whether there are any speeds that I still need a little earlier downshift (to avoid the flutter) and do the OSS logs. Once that is done, I'm hoping Torrie can figure out which table(s) are for cruise and mirror the "perfected" shift parameters there.
Just gonna take time and patience.  Thanks, Ford. After all, the car was so cheap, we should expect to have to find our own answers, right?
Quote from: John Miller on April 23, 2016, 07:37:15 PM
Fix Or Repair Daily :D
http://www.focusst.org/forum/focus-st-performance/10369-turbo-flutter.html
"This is from Braden over at Cobb:
Normal, completely. The design of the wastegate, and the low pressure spring in use make it difficult to control during high load, low rpm conditions. There is a LOT of VCT in action to create exhaust flow along with the boost control solenoid being driven at high duty cycle to allow for nearly instant spool on this engine. The factory tune delays the turbo response in these conditions partially to eliminate excessive load, but also to work around a poorly suited set of hardware. The noises you are hearing are a combination of valve overlap and aggressive wastegate dynamics coupled with a soft wastegate spring opening and closing the flapper as it is overloaded. Once exhaust flow is stabilized the system works extremely well and uses dynamics to keep boost levels near their targets.
As many have stated, downshifting is the best way to avoid these conditions. Generally, anything above 2500-3000rpm is OK in all gears, but starting lower than 2000rpm in 4-6th will net some interesting harmonics. None of which are caused by the bypass valve.
Cheers,
-Braden @ COBB"
John Miller
#148
Interesting. But .... Is the "flutter" he refers to about a sound, and not about how the vehicle is actually running as described in this thread?
Quote from: Excalibur on April 23, 2016, 06:54:06 PM
Excalibur please add your signature,thanks.  Z   :)
