Started by TimmyATL, June 02, 2015, 03:41:24 PM
Quote from: glock-coma on June 03, 2015, 09:47:06 AMI can understand that you can send power to the rear via the torque coupling. But the drive shaft is driven by the PTU and the PTU is driven by the right side cv shaft. So how would you send LESS power to the front and more to the rear if the rear is driven by the front?Unless there's some kind of active braking involved like in the Acura's SHAWD which I don't think the 13+ have.
Quote from: TimmyATL on June 03, 2015, 12:28:08 PMI think one way to know is to access the AWD module and monitor the ATC PID (paramiter identification) and see if it is a On/Off display or a percentage and do a pull and see what it reads. I do not think you can monitor the wheel speed sensors from this module so you will half to listen to the front tires for spin and seat of your pants feel when launching. Then command the ATC PID to 100% and repeat to see what happens or goes snap/crackle or pop LOL. The only way I see how this can be done is with Ford IDS software. I just started this topic to see if anyone was thinking the same thing I was. Fodd for thought
Quote from: sunwolf on June 03, 2015, 02:22:20 PMQuote from: TimmyATL on June 03, 2015, 12:28:08 PMI think one way to know is to access the AWD module and monitor the ATC PID (paramiter identification) and see if it is a On/Off display or a percentage and do a pull and see what it reads. I do not think you can monitor the wheel speed sensors from this module so you will half to listen to the front tires for spin and seat of your pants feel when launching. Then command the ATC PID to 100% and repeat to see what happens or goes snap/crackle or pop LOL. The only way I see how this can be done is with Ford IDS software. I just started this topic to see if anyone was thinking the same thing I was. Fodd for thoughtI tried commanding the AWD clutch using forscan. It turned my AWD off completely no matter what percentage I set it to. The car really lights them up with only FWD.
Quote from: sunwolf on June 03, 2015, 11:36:27 PMMaybe one weekend if we run into eachother.
Quote from: SHOnUup on June 04, 2015, 01:05:52 AMQuote from: sunwolf on June 03, 2015, 11:36:27 PMMaybe one weekend if we run into eachother.Just messing with ya...I'm thinking Milan soon. Rich
