Wtf Did I do to my sho? New exhaust makes my car sound like a rice burner
Started by 14SHOCAR, May 08, 2015, 08:05:17 PM
AJP turbo
SCT Dealer/Custom Calibrator
Specializing in 3.5 Ecoboost
Former:2014 PP SHO
405whp/520tq
Dyno
Tuning in progress
liteyouup
Comes across a lot more harsh than I really intended.  On the Honda forum I used to be on, I once heard someone describe me as "an ass online but pretty cool if you meet him."
2013 Explorer Sport
...and on that day, not one #@%$ was given.
I apologize for intefering,but this is reference to the OP.was curious to know if you used new gaskets x4,or if you re-use the old ones it will leak causing o2 sensors to read incorrectly causing fluctuations on your AFR. Z
14SHOCAR
Quote from: SHOdded on May 13, 2015, 06:07:48 PM
Is the sputtering still in the same speed/gear area or has the issue spread?
The sputtering was between 2-3 and when I put it to 91 octane it turned to 1-2 and 3-4. It also was at a different speed... and it wasn't at WOT either. When I said it got worse... it got worse. I literally pulled over on the side of the road, shut her down and put 93 back in fear I was going to EFF something up.
Quote from: liteyouup on May 13, 2015, 07:39:22 PM
We all give each other a hard time here... Consider yourself one of the EPF's....
Quote from: ShoBoat on May 13, 2015, 06:31:44 PM
Weird this sounds familiar. Wondering if this is becoming a trend.
When did you have this problem? Recently? I do you have the thread and did you get a fix? Are you torrie now?
Quote from: ZSHO on May 13, 2015, 07:49:06 PM
The Stainless Works catless DPs were either Copper ATV'd or the original gaskets were put back on ... I don't remember --
I am going to Late Model Throttle to see if I can get a data log done on the car to figure out WTF is going on with the sputter. Also I need a bit of peace of mind that nothing is majorly JACKED. They specialize in turbo charged cars and have some pretty beefy setups...
Quote from: ajpturbo on May 13, 2015, 06:10:11 PM
You really need datalogs ....I'd look at them but I'm not sure if you  log with mycal ...
If I can get the logs I'll forward them over.
on a Side note --- THANK YOU to everyone who's commented on this... there is such a wealth of knowledge here an I appreciate it.
14 Taurus SHO (Sold)
ShoBoat
2012 Pearl White CTS-V Stock
11BLKFX4EB
Is it possible that an O2 sensor got damaged during the swap? I agree the data logs would be a huge help. If sounds like a spike in AFR and the car trying to compensate wich would cause the sputtering.
2014 SHO w/ PP Platinum White
Unleashed tuned, H&R Springs, 35% tint, Corsa catback coming...
2015 Explorer Sport Magnetic Metallic-stock...for now.
Brenton keep us updated cause i know how fustrating it can be,had a few issues myself which later the dealer was able to fix under warranty,have the platinum extended warranty for a total of seven years. Z
14SHOCAR
I stopped by my tuner this morning and he is going to update his diablo tuner to see if the sputter is misfires.
I am going to reset the PCM per the previous thread in a couple of minutes here... I have a long drive down to Vernan Hills, IL from Milwaukee and back today -- which will give it a lot of drive time to adjust s***. It's super frustrating but its worth a shot.
My tuner is also going to be "test" loading a DiabloSport Tune on my vehicle. We are going to see how that tune works so I can go back to LMS to see WTF is going on.
I am getting the feeling that the LMS tune does not reset the shift points or the adaptive fuel curves when you install the tune. I think you HAVE to do a PCM reset every time to get less aggressive fuel curves. At idle, my car is spewing white exhaust on a 60 degree day -- it smells very rich (it doesn't smell like burning oil at idle).
I also am experiencing a rough idle too... Straight up frustrating.
14SHOCAR
Quote from: ZSHO on May 14, 2015, 08:36:22 AM
What was your issue?
ShoBoat
Quote from: 14SHOCAR on May 14, 2015, 11:36:26 AM
A few members have been experiencing issues with the tune files and "winter gas" blends. Judging by your location this might be the case. I know with my own testing older winter gas and ethanol blends were causing real issues with my car. I did a 1/2 tank at another station of 94 + 10% E and my car was experiencing more misfires as logged by the PCM and was pulling all kinds of timing. I have gone back since to my usual station (the busiest in my area) and the KR is much better and no misfires. Just my 2 cents.
14SHOCAR
How does adding E to your gas test* the winter blend? Don't you think that we pay for a tune to not cause misfires ... Not to cause problems... Livernois should come up with a fix for this??
I am quite confused based on so many posts and suggestions lol,would like to know if your issues started after the DP and exhaust install. Z
ShoBoat
Quote from: 14SHOCAR on May 14, 2015, 12:19:12 PM
Can't tell you an answer, all I know is what I experienced. The E is blended into the gas at the pump. We can't get anything above 91 around here that isn't 10% Ethanol. So the Ethanol may or may not be contributing to the issue. (The only reason that it might is if the gas is old and has water in it) Yes I agree that LMS should have a fix. That said it seems that if yours is the same issue as mine was we are in the minority. So a fix may not be coming anytime soon.
AJP turbo
14shocar I'm 99% sure that anytime you flash your car with a tune all the adaptives are reset...the kam is reset due to the flash process...kam is keep alive memory
Also, I highly doubt you are running rich at idle...that's where logging is the only answer rathe than speculating...the only way u would be running rich would be if u were in open loop and only a complete moron would force open loop at idle for this application....actually these cars run closed loop in a way even at wot but I won't really get into that now .....
Former:2014 PP SHO
405whp/520tq
Dyno
Tuning in progress
11BLKFX4EB
