Okay, I want to make this thread as a place to discuss different oils for the EcoBoost platform.
That being said I have a particular oil id like to talk about, Pennzoil Ultra Platinum. I have been reading into it a lot and I would like to hear what the members here have to say about it. Anyone here using P.U.P?
I would also like to consider using the 0w-40 weight instead of the listed 5w-30 for the 13+ 3.5 Eco as the 0w-40 is listed for high performance applications. Although I am not certain the 3.5 could handle that thick of an oil. Anyone using a heavy weight oil?
There is a lot of good information on this page.
http://www.bobistheoilguy.com/pennzoil-q-a/A few particular parts of interest.
Are Pennzoil Platinum® and Pennzoil Ultra Platinum™ Full Synthetic motor oils with PurePlus™ Technology available in high-performance application grades?"
"Pennzoil Platinum® Racing Full Synthetic motor oil with PurePlus™ Technology is available as an SAE 10W-60 and is suitable for many high-performance applications. Also, Pennzoil Ultra Platinum™ Full Synthetic motor oil with PurePlus™ Technology 0W-40 is recommended by SRT for their engines and Pennzoil Platinum Euro Full Synthetic motor oil with PurePlus Technology 5W-40 is recommended by Ferrari and Maserati for their engines. Pennzoil Platinum® Full Synthetic motor oil with PurePlus™ Technology 5W-50 is also suitable for many high performance applications."
"What characteristics of motor oils are important when considering them for use in modern direct injection turbocharged gasoline engines, and how do the Pennzoil Platinum® Full Synthetic motor oils made with GTL base oils meet them?""To achieve fuel economy requirements and improve vehicle performance vehicle manufacturers have moved toward smaller turbocharged engines with direct injection. These smaller engines are worked harder to achieve a higher rated output, increasing both the pressure and the temperature in the combustion chambers. These engines provide a demanding environment for the motor oil. Pennzoil Platinum® Full Synthetic motor oils with PurePlus™ Technology keep critical engine parts clean and protected, and they have high resistance to oil degradation and low volatility which helps them to maintain the protection over the oil drain interval also resulting in less need for oil top-up."
"What type(s) of testing have you done with regard specifically to your products' interaction with and ability to combat intake valve deposit formations in modern direct injection technology series of engines?""Pennzoil Platinum® and Pennzoil Ultra Platinum™ Full Synthetic motor oils with PurePlus™ Technology have undergone many stringent lab tests, industry tests, and OEM tests in addition to millions of miles of field trials. The Complete Protection benefits of the line of Pennzoil Platinum® with PurePlus™ Technology products make them an excellent choice for advanced engines, especially direct injection engines, because the motor oils help prevent deposits and perform extremely well at high temperatures. No other leading motor oil helps keep engines cleaner than Pennzoil Platinum® with PurePlus™ Technology. (Based on pistons from standard V6 engine in ASTM Sequence IIIG piston deposit test using SAE 5W-30. Does not apply to Pennzoil Platinum® Euro and Pennzoil Ultra Platinum™ 0W-40. Pennzoil Ultra Platinum™ keeps pistons up to 25% cleaner than Mobil 1; and up to 35% cleaner than Valvoline® SynPower®. Pennzoil Platinum® keeps pistons up to 8% cleaner than Mobil 1; and up to 17% cleaner than Valvoline® SynPower®)"
