PP vs. Non PP?
Started by 14 TUX BL, April 10, 2015, 11:15:50 AM
14 TUX BL
I get where you're coming from, but top automotive journals already weed out variables so the items you mention are not an issue (they've been doing it for years). Conditions are standardized as it regards weather, etc., so there is no "perfect" vs. "imperfect" day of testing. And driver variables is a non issue, remember, we have AWD.
The evaluation makes complete sense, is totally reasonable and quite trustworthy.
I'm satisfied ...
Quote from: 14 TUX BL on April 28, 2015, 10:28:09 PM
I'm satisfied ...
That's good you are satisfied but u are easily satisfied then......to be honest it means nothing really...the conditions are sooooo far from standardized....I don't care if it's 8 wheel drive..lol how do they eliminate the weather as a variable when they tested the cars at different times at different places on different days lol...it's a nice opinion of the writer but it's about the least scientific of an experiment or test that there could possibly be lol...everything I mention is an issue including that you are clueless lol
It's so close to me in performance...any little change in variables could sway the "winner", if that's what you're looking for.
My advice...throw a tune on it and have some fun...;)
Rich
14 TUX BL
Quote from: ajpturbo
Listen, you're confused.
The intent of my thread was to see observations in regards to PP vs non PP results in the "Stock Times" thread, not to appease individual people's unrestrained ego's. The thing that really destroys any credibility you may have had is your poor choice to be insulting. Also, your comments fail to add anything of value to my two decades of drag racing experience. Lastly, take note: gross immaturity is frowned upon by rational human beings.
Quote from: SHOnUup on April 28, 2015, 11:51:08 PM
Rich
A mature and intelligent comment, praise God!
It is true that 3/10 sec is not enough of a difference that someone asleep at the wheel in a PP car will beat a non PP car. But all things being equal, the PP's 3/10 sec quarter mile advantage because of it's more aggressive gearing is definitely worth the price of admission.
As far as tunes go, I've been modding since the 80's. No longer interested, my baby's staying 100% bumper-to-bumper bone stock. :-)
Quote from: 14 TUX BL on April 29, 2015, 09:39:00 AM
Rich
Agree with you on all points.  I think the use of the car as well as the desires for performance have to be weighed.  For me, I was after a DD that was quick... I don't race her... And there's no place to drive fast in this country except the track.  I wanted ACC, it really reduces my drive fatigue, compensates for traffic flow, and adds some safety... Ford won't put ACC on a PP SHO... So I chose creature comforts and daily quickness.. I did mod enough so far (see my sig) to get my 0-60 a little below 4 sec.
So that's how my choice was made.... Either version is a sleeper and a real hoot to drive.
Only things I keep drooling over not having a PP...PTU cooler, trans cooler, oil cooler....those are the key items IMO.
Wonder what the weight was on tested vehicles...tires, PP summer tires vs all season could be the difference. Tire pressure at testing. DA changes hourly and you could see a 3 tenths swing in the matter of hours. Non optioned non pp vs fully optioned PP could carry a decent weight change I think too.
So who's buying 2 brand new SHO'S? One of each to test it all out...lol ;)
Rich
Rich
68_GT
did anyone discuss the other options the PP includes ?
all things being otherwise completely equal the SHO with the lower gear ratio will have a performance advantage
2013 Ford Taurus SHO with Performance Package
The brakes get a larger master cylinder bore for a pedal ratio change that gives you less travel at the top of the pedal for a firmer feel, and the rear vented brake rotors are 30 percent larger. The already massive vented front rotors get dual piston 48-mm calipers with performance friction pads, and the pistons themselves have high-temp dust boots and seals that pull the pads more effectively away from the discs for less heat buildup.
Chassis upgrades include stiffer front springs to reduce understeer and a front anti-roll bar that's actually a little smaller to get the car to roll and pitch in a more predictable and balanced fashion. The shock absorbers have been modified for better low-speed damping, and the electric-assist steering has been recalibrated for better feedback from the big 20-in Goodyear Eagle F1 245/45 tires mounted on distinctive SHO cookie-cutter style wheels.
Extra track-day heat is carried away by a pair of water-to-oil coolers plumed into a radiator core with extra capacity. One helps the PTO on the transmission to run 16 percent cooler, and the other cools the engine oil.
In our lapping session I found the car surprisingly civilized, supple and quiet, despite its ability to turn in nicely and then drift in controlled, balanced fashion. The engine is blazingly fast down the straights and comes off the corners with hard-hitting torque (and makes a lovely sound while doing it), and the easily modulated brakes have no trouble catching the line drive to shortstop. For a big car, it bleeds off speed easily and impressively.
Complaints? Well, the seat bolsters could be more supportive for this level of track grip, and the tach face is about the size of your wristwatch. Also, I found the automatic upshifts in the Sport mode to be a bit conservative while coming off corners—though they got better the more you put your foot in it. Still, the paddle shifters are the way to go when true fun and instant gratification are called for.
That article like many written about the SHO is completely out of context where the brakes are involved. Brakes are the same with the except of the pads. That blurb is comparing Gen 4.1 to 4.2
ShoBoat
I love my PP but it's not all roses either, is it quicker than a non PP it felt a little quicker when I test drove both before purchase. The additional liquid cooling was the main reason for my choice and the ability to turn off the stability system. However I have also had my front hubs replace 3 times. These are PP only hubs lol.
2012 Pearl White CTS-V Stock
I have been doing a little research and unfortunetly there is very little credible facts to say the least between the two available,found an enthralling site which hopefully is feasible in many aspects and should benefit .Z    http://www.dragtimes.com/Ford-Taurus-Timeslip-26105.html   hopefull it will satisfy the OP questions related to this issue.Z
14 TUX BL
