What Plugs for tune
Started by TTSport15, March 24, 2015, 10:47:41 AM
TTSport15
sp 534? or are they the factory ones....So far I have 170 stat 3 bar cai and i'm waiting to hear about an sct tuner...
I Bleed BLue
Factory/Motorcraft sp534 works fine, gapped at 0.030 from all current accounts.
I would personally stick with the oem M.C SP-534 and already come pre-gapped at 0.30 which is convenient,and add just a touch of anti-seize around the threads and also apply liberally some di-electric grease inside the boots and of course on a cold engine,when installing the plugs dont make them to tight because of the aluminuim heads.Z.
PokerMunkee
How much torque when installing new plugs?
Going to tackle this in April and prepare for a tune, finally!
2011 F-250 6.2 CCSB FX4
I believe it is about 11 ft-lb or 133 in-lb.  If I don't have a torque wrench handy, I tighten them on the Edge till they are snug, then give it a 1/4 turn more (at most).  Works out about right.  But the key is never to FORCE it.  Using antisieze has its yeas and nays, if you are changing plugs frequently, you can do without.  I like to use just a dab.
http://www.ecoboostperformanceforum.com/index.php/topic,1980.0.html
TTSport15
so my xsport has the sp-534 plugs in it from factory?
I Bleed BLue
I would honestly change them only if your getting a tune and they come pre-gapped at 0.30,changed mine three times already at only 22k on her,found it convenient to use a 3/8 ratchet and plug swivel socket.Z.
TTSport15
sounds good so the sp 534 will work for me ?
I Bleed BLue
BlackJac
Quote from: TTSport15 on March 24, 2015, 12:26:50 PM
Yes, SP534. I only had about 2000 miles on mine, so I just set the gap to .030 using a good spark plug gauge from NAPA.
2017 Fusion Sport - 401A/ Moonroof/ Magnetic Grey/ Livernois Motorsports 93 Stage 3
2015 Explorer Sport  - SOLD
Modded 1980 Corvette https://www.youtube.com/watch?v=4SUDndpy8bw
I just ordered a dozen of the MC-SP534 spark plugs,best price from Rock auto.Z      http://www.rockauto.com/
Price
MOTORCRAFT Part # SP534     {#CYFS12YT3, SP528}
Category: Spark Plug
Part Image
$3.74
