New wheels! Saving some weight!
Started by shotime99, October 21, 2014, 08:30:13 PM
shotime99
5lbs per wheel is pretty good plus they are 8.5 wide!
Stock:
Braelin:
2014 Taurus SHO w/PP and H & R spring kit
Nice, can't wait to see some installed pics.
2010 RCM non PP
K&N panel filter
sp534 @ 30
unleashed 93 performance+boost 3bar
more to come.....
shotime99
Really hard to find tires in Canada lol! I tried for the heck of it 295/40r20.. ALMOST! Only problem was the rear.. On hard quick bumps the rear fender liner has 2 square sections.. When it hit those it made a horrible noise!!
I think a 35 series or 30 would work..
In order are 275/40r20.. Those are proven I do believe.. I hope!
shotime99
Here is the 295 installed..
And difference in size..
Sweet Jebus!! 295!! That's some FAT rubber.
Your the first I heard of trying to go that wide. Looks like you may have found the limit.
I can't believe you didn't have any rubbing in the front when going lock to lock.
2010 RCM non PP
K&N panel filter
sp534 @ 30
more to come.....
shotime99
the front just touched the fender liner in front of the strut. that i could of lived with.. the rear hitting there was no easy fix there!
looked bad ass tho!
shotime99
i think if there was a tire with the lower profile it would be no issue!
CroR1
what sizes will you be running now, front and back? what are the offsets on the wheels? are you running any spacers, front or rear, and what size?
by the way the wheels look nice.
shotime99
I am just going to run 275/40r20. that keeps the overall diameter the same as stock..
this is the rim
BR04 20x8.5 5x114.3mm +35 63.3mm MBK / MMF
CroR1
will the 275 clear in front? are you using any wheel spacers in the front?
shotime99
no spacers at all.. the front even fit the 295/40s rear was the issue
CroR1
nice, are you lowered or stock suspension? what do you think about the rear, can the rear wheel come a little more out to look better with tire size 275? for example that would require maybe 32mm offset? or 35 is as good and fills that fender gap with a 275? how much more room on the inside do you have, between the tire and the strut? I am really surprised that the tire is not rubbing on the strut, I would think that 32mm offset would be perfect for a 275 in front and anything bigger as in 35-39 would rub on the inside.
shotime99
I will know better tomorrow on that.. Haven't got them on the car yet
shotime99
Got them on! First drive tho.. Not liking the GMAX tires.. Very wallowy feeling.. Damn it!
I just put on gmax's today also. They're known for their soft sidewall.   Pretty sure in that size they are rated up to 51psi.
A little increase in tire pressure should help the "splashy" feeling.
