"How- to" Access Advanced Ford PIDs Using a Scan Tool
Started by breeves002, July 18, 2013, 04:04:08 PM
breeves002
Found out about a few more modules today.
The HSWM which is the Heated Steering Wheel Module. Pretty self explanatory, and then the IPM-A or Image processing module A which as far ask I know is for the auto dimming high beams.
The auto wipers may go through there as well.
Figured out what the FCM does too. Central hub for PATS and all the proximity sensors including the buttons on the door handles and keyless entry.
SHO Lover and Advanced Diagnostics Enthusiast
2008 Mercury Sable Premier - 3.5L N/A Duratec
diephieu2023
#106
Hi all. Sorry all b/c my english not good.
I have some question for modify a cheap ELM327 clone.
1. Baud rate of MS-CAN is 125k and HS-CAN is 500k. Why we convert 6,14 pin (Chip ELM clone) to 3,1 (DLC connect  to vehicle) run diagnostic MS-CAN module good? Because of it is different baud rate. I think FORSCAN app setting baud rate for ELM327 clone dongle!!!.
2. Dose ELM327 clone have set AT command same ELM327 by elmelectronics.com ? and we can setting baud rate by AT command?
Thank all very much. Have a good day for all.
