January 20, 2019, 03:30:20 PM
Author Topic: Torque PIDs...Take 2  (Read 262478 times)
Offline Gjkrisa
  • Elite Member
  • : Fairbanks, AK
  • Thank You
  • -Given: 819
  • -Received: 151
  • Ecobooster
    • Photos
Re: Torque PIDs...Take 2
« Reply #750 on: January 16, 2017, 01:16:08 AM »
Yea trying to get a log in torque but forscan may be better just takes longer to set up before I can start sliding in the snow
Offline RAYJAY
  • Jr. Member
  • : UNIONDALE PA
  • Thank You
  • -Given: 21
  • -Received: 9
  • Ecobooster
« Reply #751 on: February 05, 2017, 02:50:10 AM »
question on the pid's  i know i can read the tps  sensor on our 2013 and up  has anyone been able to read the 2010's have a f250 also would like to use torque for that reading also
2013 GREEN GEM METALLIC 402A PP PACKAGE
Offline Gjkrisa
  • Elite Member
  • : Fairbanks, AK
  • Thank You
  • -Given: 819
  • -Received: 151
  • Ecobooster
    • Photos
« Reply #752 on: February 06, 2017, 11:32:21 AM »
Do the 2010 have a tps?
Offline SHOdded
  • Administrator
  • Elite Member
  • : Beltsville, MD
  • Thank You
  • -Given: 9787
  • -Received: 3252
« Reply #753 on: February 06, 2017, 12:13:17 PM »
Save your Forscan profiles.  Reload as needed.  Easy Peasy.
Offline FoMoCoSHO
  • Super Moderator
  • Elite Member
  • : South West Ohio
  • Thank You
  • -Given: 637
  • -Received: 1085
« Reply #754 on: February 06, 2017, 09:09:48 PM »
Torque is too slow for proper logging....
You need an x4!
2018 Cmax Titanium Hybrid (Work)
Needs Ecoboost
22PLE Glass Coating
2011 Lincoln MKS Ecoboost Package (Play)
AJPTurbo FFV Calibration
15 PSI, 27 Degrees, Full Rail
Offline pmezo33
  • Elite Member
  • Thank You
  • -Given: 81
  • -Received: 195
  • Ecobooster
« Reply #755 on: September 23, 2017, 05:23:03 PM »
Anyone know if there's a way to add a pid for the o2 sensors?  I'm only getting the downstream sensors, but not the upstreams.  Is there a way to add this?
Offline Gjkrisa
  • Elite Member
  • : Fairbanks, AK
  • Thank You
  • -Given: 819
  • -Received: 151
  • Ecobooster
    • Photos
« Reply #756 on: February 08, 2018, 10:36:07 AM »
Has anyone done the work to see if there is a pid for the humidity sensor and internal temp sensor?
Also codes for controlling heated/cooled seats heated steering wheel and all the other climate controls?
I'd love to be able to get rid of sync and just install a Android tablet or pioneer nex deck.
Offline Gjkrisa
  • Elite Member
  • : Fairbanks, AK
  • Thank You
  • -Given: 819
  • -Received: 151
  • Ecobooster
    • Photos
« Reply #757 on: March 07, 2018, 07:01:28 PM »
Do our vehicles possibly have a exhaust back pressure sensor?
Offline rmkilc
  • Newbie
  • Thank You
  • -Given: 1
  • -Received: 4
  • Egobooster
« Reply #758 on: July 11, 2018, 02:27:26 PM »
In OP's CSV file with PIDs, the equation for "Bypass Valve Commanded Open" should be changed from A/256 to A/255. This will give a full value of 1 instead of 0.99609375 when the valve is open, as the hex value is FF (255) when the valve is open.
FF = 255
255/256 = 0.99609375
255/255 = 1
I know Torque will round 0.99609375 to 1 when there are no decimal places shown, but I found this issue when trying to implement the following:
If you want Torque to say Open and Closed instead of 1 and 0, use this equation:
Lookup((A/255)::0='Closed':1='Open')
Online ecoboostsho
  • Forum Supporter!
  • Elite Member
  • : Minneapolis, MN
  • Thank You
  • -Given: 143
  • -Received: 201
  • Ecobooster
« Reply #759 on: July 12, 2018, 06:07:43 AM »
FF = 255
255/255 = 1
Good catch!  I fixed the file.
2013 White SHO w/PP, Tune with AJP in progress, 3 Bar, 160T, Plugs...Mess with the Bull and you'll get the Horn. :)
Offline SHOdded
  • Administrator
  • Elite Member
  • : Beltsville, MD
  • Thank You
  • -Given: 9787
  • -Received: 3252
« Reply #760 on: July 12, 2018, 06:47:02 AM »
Thank you both :)
Offline Gray Brick
  • Sr. Member
  • : Southern California
  • Thank You
  • -Given: 32
  • -Received: 63
  • Gray Brick
« Reply #761 on: July 29, 2018, 12:53:28 AM »
I have been using the TPMS sensor PIDs for Torque for two years now.
Tablet crapped out... all other PID work on new tablet but these.
What gives?
2013 Ecoboost Ford Flex
---7.931/90.76MPH @ 5150 lbs in the 1/8th---
Online ecoboostsho
  • Forum Supporter!
  • Elite Member
  • : Minneapolis, MN
  • Thank You
  • -Given: 143
  • -Received: 201
  • Ecobooster
« Reply #762 on: July 29, 2018, 04:51:25 AM »
What gives?
What year is your flex again? (I'm on Tapatalk and can't see signatures). What is the module address you are accessing? (Header in Torque pro I believe?) If 2013+ then it should be set to 726.
Sent from my XT1650 using Tapatalk
Offline SHOdded
  • Administrator
  • Elite Member
  • : Beltsville, MD
  • Thank You
  • -Given: 9787
  • -Received: 3252
« Reply #763 on: July 29, 2018, 07:29:54 AM »
2013 flex
Offline Gjkrisa
  • Elite Member
  • : Fairbanks, AK
  • Thank You
  • -Given: 819
  • -Received: 151
  • Ecobooster
    • Photos
« Reply #764 on: December 21, 2018, 07:40:07 AM »
What gives?
On taptalk you can tap the top right then select view web page then make it jump to the last post
* Featured Topics
* Recent Topics
Re: New Intercooler for Transverse 3.5L Ecoboost
by Josephm | Today at 02:40:38 PM
This will be huge for towing!!! I am waiting for a couple of install v...
Re: 2013+ intercooler install?
by ddlopes | Today at 01:59:33 PM
Can hot pipes still be used with this intercooler? And does anyone kno...
Re: Ecopowerparts 09-14 F150 widebody kit
by 802SHO | Today at 12:19:16 PM
That looks bad a$$!  It's perfect in all the right spots...i...
by BoostfoSHO | January 19, 2019, 05:14:53 PM
New Alky pump ordered from www.Alkycontrols.comI emailed Julio over @ ...
Re: New member here transferring from other forums
by TonyTheTiger57 | January 19, 2019, 03:57:46 PM
No, there isn't a particular reason I like Fords.. It just happen...
Re: Ford Expedition & Lincoln Navigator
by ZSHO | January 19, 2019, 11:01:11 AM
2019 LINCOLN NAUTILUS RECALL ISSUED FOR 2,700 SUVSLincoln SUVs have pr...
MOVED: Toyota ecoboost
by ZSHO | January 18, 2019, 04:26:04 PM
This topic has been moved to Admin-Moderator only discussion.https://w...
Re: Throttle Body Motor assembly
by ZSHO | January 18, 2019, 06:22:19 AM
Feel free to start your own Dedicated thread here! Z https://www.ecobo...
Re: 2012+ timing job
by ZSHO | January 17, 2019, 06:28:58 PM
I believe so!  Z https://drive.google.com/file/d/0B8JUL90DXgdiMTZ...
Re: Random thoughts for the day
by ZSHO | January 17, 2019, 05:16:56 PM
JAN 14, 2019 | FORD MOTOR COMPANY PRESS RELEASEALL-NEW FORD EXPLORER G...
MOVED: Looking for used Cat-Back for A 2014 SHO
by ZSHO | January 17, 2019, 04:25:11 PM
This topic has been moved to Parts for Sale or Wanted.https://www.ecob...
Re: Splash blending e85 to 93
by FiveLeeter918 | January 17, 2019, 01:44:28 PM
Thanks to everyone! To prevent any fuel related issues god forbid I ru...
Re: Livernois Upgrades
by Livernois Motorsports | January 17, 2019, 07:45:34 AM
I just wanted to share my recent experience with Livernois and my 2018...
MOVED: Livernois Upgrades
by SHOdded | January 16, 2019, 08:09:34 PM
This topic has been moved to Livernois Motorsports and Engineering.htt...
Re: Something different?
by SHOdded | January 16, 2019, 04:29:39 PM
LOL, yes, my reference was the first gen V's, since people buy th...
Back to top
