January 20, 2019, 02:35:22 PM
Author Topic: Torque PIDs...Take 2  (Read 262470 times)
Offline ecoboostsho
  • Forum Supporter!
  • Elite Member
  • : Minneapolis, MN
  • Thank You
  • -Given: 143
  • -Received: 201
  • Ecobooster
Re: Torque PIDs...Take 2
« Reply #30 on: June 09, 2014, 08:50:15 AM »
I should have been consistent but forgot to convert that one. Apologies.
2013 White SHO w/PP, Tune with AJP in progress, 3 Bar, 160T, Plugs...Mess with the Bull and you'll get the Horn. :)
Offline Larrylu
  • Elite Member
  • : Albany, NY
  • Thank You
  • -Given: 11
  • -Received: 110
« Reply #31 on: June 09, 2014, 08:52:45 AM »
No apology needed. If were more adept at this I'd have seen that myself. Still it was kind of neat wondering if we had a chiller...if only for a moment. LOL,
Offline QuickSilver
  • Full Member
  • : The OC SoCal
  • Thank You
  • -Given: 21
  • -Received: 24
  • Ecobooster
« Reply #32 on: June 09, 2014, 09:21:25 AM »
Larry, when you say you 'added a couple of gauges' how did you do that? My Torque Pro app doesn't offer CAC or IAT2.  Did you add the PID's or what was the process?  Keep it 5th grade level if you can, I'm a hardware/pull a motor kinda guy not a software/write code kinda guy :-[
AJ
2014 Ingot Silver Explorer Sport- LMS V3 Tune, AirRaid CAI, Hi_flow Catted DP's to Complete dual 2.5" exhaust, 19"X 9.5"TSW Panorama Rotary Forged/powdercoated Rims, Cree LED Foglights, Hoping for those Megan coilovers to be developed...
Offline Larrylu
  • Elite Member
  • : Albany, NY
  • Thank You
  • -Given: 11
  • -Received: 110
« Reply #33 on: June 09, 2014, 09:43:22 AM »
QuickSilver I'm the student in this thread just following instructions.   One of the first thing you run into with Torque Pro is the lack of some of the cool gauges that other Mfgs seem to have out there but not for us Ford folks. It seems Ford PID's are very hard to come by. Then ecoboostsho decides to singlehandedly make some PID's available for the rest of us grateful users by reverse engineering. He has already put out some very good instructions for using the "add custom PID" menu in Torque and you should be able to easily find it.  If not ...speak up. Someone will help. I will pause to let more knowledgeable people handle your questions
Offline EcoPowerParts
  • How can I help you today?
  • Elite Member
  • : Phoenix
  • Thank You
  • -Given: 140
  • -Received: 1060
    • EcoPowerParts
« Reply #34 on: June 09, 2014, 09:46:51 AM »
Great job on this! Next step will be to make a csv file so people can easily import the PIDs into Torque
Offline ecoboostsho
  • Forum Supporter!
  • Elite Member
  • : Minneapolis, MN
  • Thank You
  • -Given: 143
  • -Received: 201
  • Ecobooster
« Reply #35 on: June 09, 2014, 10:56:42 AM »
PID Installation Instructions: (also updated in first post)
Bulk Import: (Note I’m not sure this will really be easier for someone that isn’t a little familiar with windows and basic computer functions.  You may be better off manually entering them one at a time – see procedure below.)
The following will let you add all of the PIDs defined in this post to Torque via the “Import” feature on Torque.
Your first step is to hook up your phone to your computer via a USB cable (the one you more than likely charge your phone with).  You can do this in other ways as well but you need to put the attached “Taurus PIDs.csv” file in the proper Torque directory on the phone. Open up a file explorer and then navigate to the drive letter that is your phone.  You should see some directories (varies by phone and number of storage cards).  Torque should be on your internal SD card (Unless you told it to go someplace else or your phone directed it there) and the directory you are looking for is labeled “.torque”.  If you don’t see .torque you are going to have to “show hidden files” in windows explorer – this varies by version so I suggest you Google it.  You then select the “Extended PIDs” directory.  Copy the attached file in to that directory and then disconnect your phone.
Once that file is there you can select the “settings” menu off the main screen…scroll down to “Custom PIDs” and then “Import”.  You should see “Taurus PIDs” listed in the menu.  Select them and then go add them to your screen!
WARNING: You may choose to “clear the list” of the existing custom PIDs to keep things cleaned but keep in mind this will strand any gauges you already have on the screen unless they are named exactly the same as in the import file.  This means you will have to add them back to the screen one at a time and you may be “irritated”. :)
Adding a single PID:
Add a custom PID in Torque by going to the "Settings" section off the main screen.
Enter the following for the fields it prompts you for:
"OBD2 Mode and PID"  =  221E1C
"Long Name" = Trans Temp
"Short Name" = Trans T
"Minimum Value" = -40
"Maximum Value" = 260
"Scale Factor" = 1
"Unit Type" = deg
"Equation" = (((signed(A)*256)+B)*(9/8)+320)/10
Leave the OBD Header blank
Adding gauges to your Torque Screen:
Go to the Realtime Information display from the main menu and then find a place on the screen you’d like to put your new gauge.  Long press and then “Add Display”.  Pick a gauge type and then scroll to find your new PIDs.  Position it on the screen and then repeat the whole process until your gauges are all populated on the screen.
*Final note.  If you open the .CSV file in Excel be careful as it will immediately interpret two of the PIDS as “exponential notation” and hose them up…You can open the file without issue just don’t save it unless you know what you are doing! :)
(I removed the file from this post and am going to just leave it on the first post so I only have to update it one place.  Just click on the "1" to get to the first page of the post.)
« Last Edit: June 11, 2014, 06:48:06 AM by ecoboostsho »
Offline Larrylu
  • Elite Member
  • : Albany, NY
  • Thank You
  • -Given: 11
  • -Received: 110
« Reply #36 on: June 09, 2014, 11:12:47 AM »
For those of you who see a smiley face with sunglasses in the above formula, (like me) be advised that the correct replacement for that smiley face is the number 8. LOL
Offline ShoBoat
  • Elite Member
  • : Canada
  • Thank You
  • -Given: 88
  • -Received: 255
  • Ecobooster
« Reply #37 on: June 09, 2014, 11:19:05 AM »
Has anyone had any luck with oil pressure? I can't seem to get it to work.
2012 Pearl White CTS-V Stock
Offline Larrylu
  • Elite Member
  • : Albany, NY
  • Thank You
  • -Given: 11
  • -Received: 110
« Reply #38 on: June 09, 2014, 11:21:37 AM »
QuickSilver you might want to just add one custom formula at a time by following the above "add a single PID" instructions. I think it's easier to start with.  After inputting all the info at the bottom of the screen you will see a test button press that and if you get a "result" you can press the save button. Then go to your gauge display to where you can add a gauge and when you scroll the list of available gauges you will find the one created by your new custom PID.
Offline Larrylu
  • Elite Member
  • : Albany, NY
  • Thank You
  • -Given: 11
  • -Received: 110
« Reply #39 on: June 09, 2014, 11:24:49 AM »
We don't have the PID for that one in torque. So far that's not one of the custom PID's ecoboostsho has succeeded with. Maybe someday....
Offline ecoboostsho
  • Forum Supporter!
  • Elite Member
  • : Minneapolis, MN
  • Thank You
  • -Given: 143
  • -Received: 201
  • Ecobooster
« Reply #40 on: June 09, 2014, 11:41:15 AM »
Hmmm...I don't remember seeing Oil Pressure as an option anywhere in my existing scantool.  If it is I could certainly figure it out.  Let me see if it's there and I will get back to you.
Offline Larrylu
  • Elite Member
  • : Albany, NY
  • Thank You
  • -Given: 11
  • -Received: 110
« Reply #41 on: June 09, 2014, 11:51:50 AM »
Larry.  CAC is in degrees C. Multiply by 1.8 +32
Thanks ecoboostsho. That tweak to the formula worked like a charm. Now I'm showing a steady progression of IAT's warming as they wend their way through the hot plumbing.
Offline SHOdded
  • Administrator
  • Elite Member
  • : Beltsville, MD
  • Thank You
  • -Given: 9787
  • -Received: 3252
« Reply #42 on: June 09, 2014, 12:11:24 PM »
A video of your new setup would be awesome, Larry!  Hint, hint :D
Offline ecoboostsho
  • Forum Supporter!
  • Elite Member
  • : Minneapolis, MN
  • Thank You
  • -Given: 143
  • -Received: 201
  • Ecobooster
« Reply #43 on: June 09, 2014, 12:13:21 PM »
It doesn't look like oil pressure is available...
Offline Larrylu
  • Elite Member
  • : Albany, NY
  • Thank You
  • -Given: 11
  • -Received: 110
« Reply #44 on: June 09, 2014, 12:19:46 PM »
I've posted pics but never videos. Do I use the same procedure to post a video?
* Featured Topics
* Recent Topics
Re: New Intercooler for Transverse 3.5L Ecoboost
by Agentlongwood | Today at 02:08:58 PM
Sigh... want one so dang bad.  Can't get it passed the wife ...
Re: 2013+ intercooler install?
by ddlopes | Today at 01:59:33 PM
Can hot pipes still be used with this intercooler? And does anyone kno...
Re: Ecopowerparts 09-14 F150 widebody kit
by 802SHO | Today at 12:19:16 PM
That looks bad a$$!  It's perfect in all the right spots...i...
by BoostfoSHO | January 19, 2019, 05:14:53 PM
New Alky pump ordered from www.Alkycontrols.comI emailed Julio over @ ...
Re: New member here transferring from other forums
by TonyTheTiger57 | January 19, 2019, 03:57:46 PM
No, there isn't a particular reason I like Fords.. It just happen...
Re: Ford Expedition & Lincoln Navigator
by ZSHO | January 19, 2019, 11:01:11 AM
2019 LINCOLN NAUTILUS RECALL ISSUED FOR 2,700 SUVSLincoln SUVs have pr...
MOVED: Toyota ecoboost
by ZSHO | January 18, 2019, 04:26:04 PM
This topic has been moved to Admin-Moderator only discussion.https://w...
Re: Throttle Body Motor assembly
by ZSHO | January 18, 2019, 06:22:19 AM
Feel free to start your own Dedicated thread here! Z https://www.ecobo...
Re: 2012+ timing job
by ZSHO | January 17, 2019, 06:28:58 PM
I believe so!  Z https://drive.google.com/file/d/0B8JUL90DXgdiMTZ...
Re: Random thoughts for the day
by ZSHO | January 17, 2019, 05:16:56 PM
JAN 14, 2019 | FORD MOTOR COMPANY PRESS RELEASEALL-NEW FORD EXPLORER G...
MOVED: Looking for used Cat-Back for A 2014 SHO
by ZSHO | January 17, 2019, 04:25:11 PM
This topic has been moved to Parts for Sale or Wanted.https://www.ecob...
Re: Splash blending e85 to 93
by FiveLeeter918 | January 17, 2019, 01:44:28 PM
Thanks to everyone! To prevent any fuel related issues god forbid I ru...
Re: Livernois Upgrades
by Livernois Motorsports | January 17, 2019, 07:45:34 AM
I just wanted to share my recent experience with Livernois and my 2018...
MOVED: Livernois Upgrades
by SHOdded | January 16, 2019, 08:09:34 PM
This topic has been moved to Livernois Motorsports and Engineering.htt...
Re: Something different?
by SHOdded | January 16, 2019, 04:29:39 PM
LOL, yes, my reference was the first gen V's, since people buy th...
Back to top
