Picked up the truck from suspension work late Friday night on the Tremor, new one piece drive shaft, moved shocks inside the frame rails, VSS traction bars and raised the front so that that steering will go full lock without hitting the lower control arms. I also had them cut the muffler off so it was just stock down pipes and exhaust but it stopped just after the cab.
Saturday I went to a local CHEAP muffler shop and had them do an out the side exhaust and tip, he only charged $100, I asked him about installing my MAK PoS 3" catless steel DP and he said another $100, so home and back I went so he could install. Also had him shorten them up so they don't hang out under the truck now.
Video of new exhaust which sounds craptastic so I am putting in a muffler this week and also having him weld on my 3" boost activated cutout I have in the garage.
! No longer availableNext step?
Aux fueling!!!!
Found a way to make an intake manifold pretty inexpensively, just need a controller, hoping ProSpeed will do for us what they did for the GM stuff with CAN integration into stock ECU. I also have a 2 step on the bench and need to wire up the trans brake setup.
