HID Project Change
Started by geswek, May 12, 2014, 10:18:54 PM
geswek
I have a buddy here who just opened his shop; does a lot of custom work and his team is amazing.
He recently got a hold of one of the best retro guys in the area; seen this dudes work and it's amazing.
I was talking to him about changing out my HIDs for something better as I recall someone doing that to a Canadian car.
I guess my question is; do you guys think it's worth the investment to have much better lighting then the OEM setup? I'm thinking a different projector housing would be a good upgrade since OEM isn't that great.
Thoughts?
LowFrequencies
If they're using higher quality retrofit kits, it can get expensive but the light output will be a night and day difference.  When done correctly, you can get a much better light output and crisp/clean cutoff lines.
2012 F150 XLT 4wd Ecoboost in Tuxedo Black
- Performance: LMS 93 Tune, Airraid CAI, Heartthrob Exhaust, Offroad Package (factory rear locking diff + 3.73 gears)
- Exterior: BDS 6" Suspension Lift + 2" Leveling Kit, 35x12.50r20 Open Country M/T on 20" Ballistic Jesters, 6000k HIDs in High/Low/Fogs, Recon 3rd Brake Light, LED Tails, LEDs, Switchback Turn Signals, Powdercoated Bumpers
- Interior: Hatchie Bottom Armour-Suede seat covers, White Dome LEDs
- Audio: Pioneer AVH-P4400BH Screen pushing Rockford Fosgate T1 6.5 Components and 6x8s, Rockford Fosgate T1000-1bdCP with 2x Sundown SA-10s
ShoBoat
Quote from: geswek on May 12, 2014, 10:18:54 PM
Thoughts?
That would have been mine, I did the retro, also I think someone did their explorer also.  Cost isn't that bad. About $500 if you do the work yourself. Here is an output shot.
I have others, I'll have to find them.
2012 Pearl White CTS-V Stock
MDesign Performance
Purchasing some proper bulbs would be a start and you might actually like the results, look at Osram Xenarc D3S 5000K Bulbs. The authentic ones are made in Germany so make sure you purchase from a reputable source.
sales@mdesignperformance.com
www.mdesignperformance.com
explorergotoluvit
#4
lightwerkz.net did mine and it truly is a huge difference in light output they can clear out lenses and make them be a wider output as well with new projectors. I have done two retro on my own with help of one of my buddy's.  One on a wrx replacing projectors the were halogen and one the was a bugeye wrx with housing.  The were for left hand drive and we converted to Right hand and in that one we put tsx projectors in and the output of them and at the time were the best but now i believe there are better projectors but it just depends on how much to spend and how much you light output on the road but I truly believe that it well worth it.
For another example, the limited explorers have terrible lighting output i first thought that they weren't even HID's because the projector was so bad.  So lightwerkz did new projectors and bulbs and it made a huge difference. This is just my input hope it helps
I do have a post of mine in the explorer part of this forum but recently took my 4300k bulb out and  did 5500k ones. I felt like the 4300 were a little yellow and wanted more of a pure white. They say the 4300k have more lumens then the 5500k and thats why I went with the 4300 first but just felt like going with the more pure white output.
2013 explorer sport
LMS tuner stat 160 3 bar magna flow v8 91 map
k&n H&R spring
retrofit FXR bi-xenon projectors done by lightwerkz
all lights replaced with leds from daytimebrightlites
ShoBoat
There is another Canadian member that is using Prolightz to have this done, here is the link to my retro. I just realized the pics are gone. I will repost them later today. http://www.ecoboostperformanceforum.com/index.php/topic,2221.0.html
MDesign Performance
The only reason I say to try out different, high quality bulbs is because I actually have experience in this field. I use to offer the service on the Malibu forums when I had my Malibu therefore I know the work involved, linked below:
http://www.chevymalibuforum.com/forums/showthread.php?t=7413
As far as it being better than the OEM projectors, I think it is more cost effective to spend $80-100 on German made Osram Xenarc bulbs and if you believe you need more improvement I would then look into projector retrofits. Being cost effective isn't the only advantage, you'll also have the advantage of never having your headlights split and won't ever have to risk the small chance (depending on your retrofitter) of condensation in the headlight.
ShoBoat
You will get a better output from a rebased hid bulb, that said halogen projectors are just that. They are designed for halogen bulbs. The throw of light is pushed forward and not to the sides. Hence the smaller reflector. Here is a before pic of mine with Morimoto hid 6k bulbs in them.  as you can see the pattern is not anywhere like a true hid projector. I have been down this road, also you will need to lower you alignment as to not blind oncoming traffic. Halogen projectors typically are not stepped, meaning that the light cut off is flat. Defeating the nice shinny bulbs you just put in there. If you are going that route, like it's stated get good bulbs and good ballasts. Cheap bulbs will yellow your projectors over time due to the extra uv they put out.
ShoBoat
That is really cheap for D3S bulbs. They would drop right into the OEM hid housing. I wonder why they are so cheap? Usually these are closer to $200
geswek
LOL; no idea but I just searched for what Spartn said.
They have DOT German tag and I looked up other sites; like Audi forum and guy posted same kind of tag on his.
MDesign Performance
Quote from: ShoBoat on May 13, 2014, 10:11:42 AM
That is true, though the OP is interested in going from OEM HID Projectors to aftermarket HID projectors from what I understand, also looked up his bulb which is a D3S HID bulb.
This is why I suggest a simple bulb swap to the OP as the vehicle is already equipped with HID projectors with the proper cutoff.
MDesign Performance
#12
Quote from: geswek on May 13, 2014, 11:42:57 AM
The price seems right, that is for 1 bulb so it would be closer to $100 for a pair which is what they go for. These bulbs come on the newer Audi's which is that crisp white light that everyone is after. You just have to make sure they're authentic and get them from a reputable source as there are fakes.
Here's some info:
http://www.audizine.com/forum/showthread.php/494819-eBay-Osram-Xenarc-5000K-D1S-bulbs-with-photos
geswek
Quote from: Spartn27 on May 13, 2014, 11:50:12 AM
Here's some info:
That's the thread I read.
They look the same.
I do want that crisp white color; mine seem weak imo.
The ones he linked are D1S; I need D3S right?
explorergotoluvit
Quote from: ShoBoat on May 13, 2014, 11:41:51 AM
fake there not the real thing
2013 explorer sport
k&n H&R spring
