Quote from: toreli on May 01, 2014, 05:41:09 AM
if the fans will not come on until 212 degree with factory thermostat with only LMS V8 tune it is a problem!
(if true LMS must notify that using factory thermostat with V8 tune may cause serious engine problem)
On their tuning order page :
http://www.livernoismotorsports.com/products/AIW-2013-Taurus-SHO-MyCalibr8or-Tuning-Device.html] [url]http://www.livernoismotorsports.com/products/AIW-2013-Taurus-SHO-MyCalibr8or-Tuning-Device.html[/url]
...LMS does recommend cooler T-stat... and the tune is modified for earlier fan turn on too... I have tested in mine. They state:
"**For maximum performance and the best drive-ability, Livernois Motorsports highly recommends the use of our EvenFlo 160* thermostat with the purchase of all MyCal tunes.**
*You can add a thermostat to this order with no extra shipping charge.*
*We highly recommend our pre-gapped spark plugs for any performance tune.*"
and the go on to say....
"Any unforeseen damage that may happen to the vehicle will not be covered or guaranteed by AIW or Livernois Motorsports in any way. If anything doesn't feel normal after loading a tune, it is the customer's responsibility to immediately return the tune to stock, and notify Livernois Motorsports immediately."
What more should they say?
If you simply tell LMS up front (they do ask on the order page) for mods such as t-stat, or follow their instructions and call them they will add the modded fan on and off temps.
