Quote from: geswek on March 22, 2014, 10:53:20 PM
Quote from: SwampRat on March 22, 2014, 10:51:56 PM
IF IM WRONG I'll eat MY SHOES ...
I will look closer at mine when I get back home . I dont beleve there is any internal tubing connection , they are just welded together to eliminate vibration .
I'm pretty damn sure that's an x-pipe. If it isn't I'm going to be pissed off and I'll have it cut and one put in but from what I saw outside; it sure looks like one.
I'll call Corsa Monday and ask.
I just looked at instructions; they say it's an XO pipe--again I'm fairly certain that's an x-pipe.
Any body know what is the best seasoning for Merrells .... LOL
I Stand corrected .... below is from Corsa's Website :
What is a Cross-Over Pipe and what does it do?
An XO-crossover pipe allows the exhaust flow from both banks of the engine to mix and balance out which creates improved flow characteristics and a more pleasing exhaust note. It can also help reduce some of the trailing throttle burble characteristic of certain engines. In some cases, the blending of the exhaust can help accelerate the exhaust gases enough to improve the scavenging of the combustion chamber and free up a few extra HP.
What is the difference between and XO-Crossover pipe and an H-Pipe?
An XO-crossover pipe brings the two exhaust pipes together in an "X" shape so there is true cross-over between the pipes. An H-pipe keeps the flow paths separate and simply tries to balance the exhaust gas pressure and flow; these are often referred to as 'balance tubes.' CORSA's crossover pipes are designed to reduce turbulence and blend the air to create the most performance and perfect CORSA sound.
