Cecil County Dragway 3/21/2014
Started by geswek, March 21, 2014, 10:36:26 PM
black99lightning
Quote from: geswek on March 22, 2014, 05:52:45 PM
I'm ordering DP next week. I want to see difference. I do agree the stock are horrible.
I do think dropping the 3rd muffler in place of X in Corsa helps tremendously.
Sent from my mobile, I think.
Forgot the Corsa replaced that with an X pipe.
2013 Esport 13.44 @ 103.6
1999 Lightning 12.44 @ 108.4
2012 GT500 10.96 @ 130.6
2006 GTO 12.83 @ 107.8
2013 CTSV coupe 11.79 @ 119.7
Quote from: black99lightning on March 22, 2014, 06:23:30 PM
Corsa does not have an  X pipe  ...
I would agree....  I would add an X-pipe and then just do tips if you want aesthetics.
Another way to go is what I plan... an X-pipe with a boost activated and solenoid switched oversized cutout in it installed in the downpipes just ahead of the flange to the rest of the exhaust... This was developed by Mike B, and graciously loaned back by FoMoCoSHO to allow Paul at PPE out here to construct a jig ... several of us are waiting on this.... It is in progress and we all hope it can be mass produced and bought through EBPP soon.
I realize other tastes exist.... but I wanted zero restriction under performance conditions, given what we know about CAIs and flow restriction in the SHO, and still wanted a more sedate exhaust note for just cruising.... absolute best of both worlds IMHO.
Quote from: geswek on March 22, 2014, 05:41:07 PM
Sigh.
You guys need to educate yourselves.
Different wheels, less rotating mass.
Different tyres, better traction. F1 suck period.
Lower car with stiffer springs, better launch control and less spring rock translate to keeping suspension solid. If you raced motorcycles you understand this.
Exhaust gives better Turbo efficiency through flow.
Intake, it looks nice.
This is not tune only. I would not be running 12.5 with only a tune. Why, because my friend has same car, with just intake and LMS 93 octane and could not get out of the 13s.
geswek!!! YOU SCARED ME!!!!! It looked like you had taken my fastest "TUNE ONLY" Time record over 12.669sec. That with LMS 93, CAI, 59 deg, and DA 700.
Quote from: crash712us on March 21, 2014, 11:08:54 PM
Nice times!
HA "crash" take a look at geswek and my 12.5 and 12.6 time sheets. Steve try to teach me the why but I still don't get it. why do I have so fast times but so slow trip speeds. And why my car is faster in the 1/8mi but slower in the 1/4mi than geswek on the two runs?
geswek
#20
Quote from: SwampRat on March 22, 2014, 06:54:41 PM
Look again; very top of image--that is an X-pipe. I visually inspected it and it is two pipes welded together in place of muffler or whatever use to be there.
Quote from: shoman04 on March 22, 2014, 08:53:21 PM
You're losing top end; I keep pulling past 60mph. That is why I'm faster.
Also; that claim is a little bias--because if I recall you had stock wheels and those are lighter than the Flower Power wheels on the 13's. Don't you have Eibach's? Wheels and suspension affect times--regardless of what people say.
Either way; for what we have--those are insane times when I'm seeing 5.0 Mustangs running a whole second slower than me and weigh less than I.
Original post is updated with video my friend took of both 12.5 runs.
Quote from: geswek on March 22, 2014, 10:43:13 PM
IF IM WRONG  I'll eat MY SHOES ...
I will look closer at mine when I get back home . I dont beleve there is any internal tubing connection , they are just welded together to eliminate vibration .
geswek
#22
Quote from: SwampRat on March 22, 2014, 10:51:56 PM
I'm pretty damn sure that's an x-pipe. If it isn't I'm going to be pissed off and I'll have it cut and one put in but from what I saw outside; it sure looks like one.
I'll call Corsa Monday and ask.
I just looked at instructions; they say it's an XO pipe--again I'm fairly certain that's an x-pipe.
If geswek's gonna cal... that will be the answer... please no ingestion of clothing... LOL
If you DL the installation instructions from Corsa, they do call the area where the pipes are joined an X-pipe... I think they hold a patent on that design of one.
Quote from: geswek on March 22, 2014, 10:53:20 PM
Any body know what is the best seasoning  for Merrells .... LOL
I Stand corrected .... below is from Corsa's Website :
What is a Cross-Over Pipe and what does it do?
An XO-crossover pipe allows the exhaust flow from both banks of the engine to mix and balance out which creates improved flow characteristics and a more pleasing exhaust note. It can also help reduce some of the trailing throttle burble characteristic of certain engines. In some cases, the blending of the exhaust can help accelerate the exhaust gases enough to improve the scavenging of the combustion chamber and free up a few extra HP.
What is the difference between and XO-Crossover pipe and an H-Pipe?
An XO-crossover pipe brings the two exhaust pipes together in an "X" shape so there is true cross-over between the pipes. An H-pipe keeps the flow paths separate and simply tries to balance the exhaust gas pressure and flow; these are often referred to as 'balance tubes.' CORSA's crossover pipes are designed to reduce turbulence and blend the air to create the most performance and perfect CORSA sound.
At that time I had just LMS 4+ TUNE AND AirAid CAI But my car is a PP option. And it weight only 4165lb at the track with out me (NO OPTION BUT 12S PP ). Even now I don't have the Eibach's
Night Hawk
I can understand why you would want to remove the resonator but why would you use an x  pipe instead of 2 straight pieces of pipe ?
It looks to me that this is taking  the exhaust from each downpipe and merging it  in the cross section  causing at least some turbulence and restriction before splitting again into the rear dual exhaust .
The  Corsa  does not do this and has no x pipe.... its straight through .   prepare for shoe consumption!!
  I took a photo today of my corsa kit not on the car yet there is a diamond shaped whole approx 31/2" by 2" tall.  Corsa is an x pipe.  I guess the x pipe set up if you delete the resonator and just weld in mufflers is a good low cost option.
2017 Fusion Sport
GFB DivValve/165* Thermo
K&N Panel/CFM Breather
Ult Perf Int Garrett Core/MKZ oil cooler
FMS 70mm TB/ NGK .026/LMS V6 93
geswek
That is Corsa X pipe design, they hold a patent on it. Called the XO pipe.
The whole purpose is to equalize pressure and scavenging.
Night Hawk
  Yea thats the point I was making about x pipes vs separate duels.
2017 Fusion Sport
Night Hawk
Quote from: shoman04 on March 23, 2014, 06:00:27 AM
Didn't you have dynomax exhaust too shoman?
2017 Fusion Sport
