I have to thank LMS for working with me. They did a wonderful job getting this tune tweaked.
I have been trying a few 3 bar tunes lately (fan settings too) and the 93v8 3 bar is by far the best one so far.
It's smooth and shifts better. I do feel the increase in power at the higher RPM range compared to the 2 bar. Can't tell if there is any more initial power (torque) but it feels there is more higher rpm end HP, and my Dashcommand says there is. Boost also hit 16.1 lbs at one point.
I ran this in 40 and 50 degree temps and not one hesitation anywhere so far.
Other change from 93v7 2 bar is it does like to down shift a little sooner on partial acceleration instead of staying in higher gear lower rpm and using torque to accelerate. This is similar to what I experienced in the cold weather tunes (the shifting only), the power is greater though than the cold weather tunes.
It also seems more controlled in daily driving in respect to stop and go or stop and really going.
Can't tell you for sure if it's truly faster, but I would bet it is slightly.
I'm stock except for colder plugs at .030, drop in K&N and 170 TS.
