And what kind of 'let-off' pressures are you likely to see with stock turbos?
Also, Is that directly correlated with the psi you're creating?
ie. if I spool up 15lbs and let off the gas, ending the boost cycle, are the BOVs met with all 15lbs, or would it only be a percentage of that, that is 'blown-off'?
THANKS!
