If there is a control method built into the OE tune tables which limit boost based on a variable such as temp (air density), then I would surmise that as being a failsafe or protective measure of sorts.
Anyway, if I understand correctly, Livernois has built a tune for the following configuration -
93 octane, 170tstat, 3 bar, no meth
Is that correct? So, what, I assume the only thing that is manipulated is more boost?
Also, is Livernois dabbling at all in tuning for E? I mean, even for mild blends, such as E20.
I'm ignorant to the facts, but I believe I saw mention of the 13+ fuel system, namely the HPFP being able to deliver more fuel than previous models. When is it that the injectors are no longer able to keep up? 4DR also mentioned the in-tank pump being a restriction...
