Incoming new product JMS Boost Max.
Started by tmcphail, January 26, 2014, 05:56:54 PM
tmcphail
I will have a test unit here soon but this is actually a neat device. For one it can be used along with custom tuning and give you the ability to adjust boost inside the vehicle on the fly. And it can also be used on its own to allow a completely warranty friendly way of turning the boost up without the need for a programmer or reflashing the vehicle. I have been a JMS dealer for a long time and have access to all of their products.
PDF link to the 2014 catalog go to page 15
www.jmschip.com/content/JMS_2014_Catalog_Web.pdf
Take care,
Mr. Torrie R. McPhail - Owner
Unleashed Tuning Ford/GM/DCX SCT Custom Calibrator
EcuTek Nissan R35 GTR Custom Tuner
HPTuners Custom Tuner / Dealer
Torrie for the upgraded turbos would this be a good solution along with a custom tune?
It would be awesome to see if they could come up with a RPM based boost map with it.
I can't read the images you posted so I don't know if that's an option already.
Josephm
What's the price point? I would like to combine this with a tune .
Sorry if it is in catalog. On phone
12' Flex EB
Unleashed X4
3rd Cat delete
tmcphail
It will be under $300. It modify's the pressure curve that is being commanded through the calibration either up or down. So yes it will work with or without custom tuning. Just depends on the end goal.
Take care,
Josephm
12' Flex EB
Unleashed X4
3rd Cat delete
Have to check this out more when I have time.  ..... WOW
Josephm
12' Flex EB
Unleashed X4
3rd Cat delete
tmcphail
Take care,
Quote from: 4DRHTRD on January 26, 2014, 06:28:56 PM
Great idea!
Josephm
I take it, it has fail safes built into it. To prevent someone from cranking it, and over boosting? Or will the Ford ECU shut it down before it comes to that?
12' Flex EB
Unleashed X4
3rd Cat delete
boostedflex
Hey Torrie,
Any thoughts on tranny issues?  I am not an expert, but without the firmer shifts when using this stand alone, could their be issues with slippage?  Along with that, any concerns on line pressures at part throttle?  I toasted a tranny in a 96 Z-28 due to an overly oiled K&N, so things like this scare me a bit.  I have to say if this pans out, I REALLY want it :)
Thanks
2017 Explorer Sport
Stock
2012 Flex, sold
Unleashed 93 tune, 170 degree t-stat, Airaid intake, Motorcraft SP534 plugs
SRT82ECOBOOST
So I guess I need this explained to me exactly what benefits this gives you when a custom tune is already in play?
bigmoneycloser
My exact question....
If you have a custom tune already..
And then you increase the boost..it sounds like a disaster about to happen.. The tune already increases the boost to higher "safe/tested" boost levels and then if you increase it more????
Or I'm just not understanding??
2014 Explorer Sport 401A
vernonator
If you read the catalog page provided it states it "compatible with JMS Custom Tunes"....is that accurate? (I would hope it is being from their catalog and all). And does that imply ONLY JMS Tunes?
2012 Tuxedo Black SHO w/PP. Livernois Stage 4+, PPE Catless DP's, EBC Stage 4 Front/Rear Brakes
2015 Tuxedo Black Explorer Sport 401A, no mods....YET :)
