So..... If you were going to run this set up with a custom tune.. Would the tune actually be set up with a lower boost setting to give you the ability to increase or decrease boost?
Because if the tune is already set up at "Maximum" performance levels and then you turned up the boost... Wouldn't that be bad??
I'm assuming a custom tune from whomever... Is set up for the maximum performance the vehicle can safely handle..
Sent from my iPhone using
Tapatalk
