interesting read. parts of a 2014 SHO PP owners manual
nformation Displays AWD Messages Change AWD Power Transfer Unit Lube 123 Action / Description ...when the AWD system needs its power transfer unit lubrication changed. This message may be set if a vehicle has experienced extended periods of extreme/severe duty cycle driving. See your authorized dealer for service. (Taurus SHO Performance Package Only) Action / Description Battery and Charging System Messages Check Charging System ...recovery. Contact your authorized dealer as soon as possible. Contact your authorized dealer as soon as possible. 2014 Taurus Owners Guide gf, 1st Printing, April ...
...any normal scheduled maintenance. Do not check or change the PTU lubricant unless the unit has been submerged in water or shows signs of leakage The Power Transfer Unit (PTU) in Taurus SHO™ performance package vehicles is... notifies the driver of required service by displaying the message Change AWD Power Transfer Unit Lube in... PTU lube will be more likely to require a fluid change if the vehicle has experienced extended periods... duty cycle driving. Do not check or change the PTU lubricant unless the unit has been... and to reset the PTU lube life monitor. 2014 Taurus Owners Guide gf, 1st ...
