Started by n8rfastback, December 21, 2013, 07:59:11 AM
Quote from: B. Rock on December 06, 2016, 01:08:54 PMQuote from: polskifacet on April 13, 2016, 03:07:27 PMFor non PP you dont have to remove anything. You can fit your hand and a wrench next to the ptu and fairly easily unscrew the plug. Drilling and tapping the ptu is really the way to go for draining otherwise you have to do magic to get a good amount of fluid sucked out through the fill plug.You can see the plug sticking out a bit where the o2 sensor ends.How bad was installing the plug? Looked pretty tight to get a drill in there when I eye-balled it this past weekend.
Quote from: Randy Stinchcomb on January 26, 2017, 12:33:14 AMCan't you use sumthing like a Jabsco pump and suck it up and out thru the fill??Explorer if that makes a difference
