February 08, 2023, 11:21:26 AM
Author Topic:  Low mpg bad fuel economy  (Read 4948 times)
Offline Mml665
  • Jr. Member
  • -Given: 3
  • -Received: 1
  • Liked:
  • Likes Given: 0
« on: November 05, 2022, 12:01:45 PM »
So I noticed poor fuel economy, but I figured my driving style was the cause, however the roommate (aka: legal partner/wife) lol has been daily driving the Lincoln for a month and is complaining.  Her driving style is not spirited like mine.
Daily commute is 22 miles and is going thorough a tank  in 5-6 days
Would worn plugs and or coils cause a drastic change in mpg?
If so what plugs and coils are recommended?
« Last Edit: November 05, 2022, 12:09:25 PM by Mml665 »
Offline Macgyver
  • Super Moderator
  • Eastern Pa.......
  • -Given: 100
  • -Received: 396
  • 2020 Red ST
  • Liked:
  • Likes Given: 37
Re: Low mpg bad fuel economy
« Reply #1 on: November 05, 2022, 03:32:26 PM »
Plugs for sure can cause bad MPG. So can Winter fuel if you live in the north.
A stuck injector will as well butt that should throw a code.
A vacuum leak will cause bad MPG.
Scan for codes and see what happens there.[size=78%] [/size]
So you are saying. 150 ish miles and you are going through 15 gallons of gas ? Thats 10mpg.
Offline SHOdded
  • Forum Supporters
  • Beltsville, MD
  • -Given: 13068
  • -Received: 4257
  • Liked:
  • Likes Given: 153
« Reply #2 on: November 06, 2022, 01:53:33 AM »
MY, mileage, maintenance history, ambient temps at cold start ...
22 miles roundtrip or oneway?
remote starting / extended idling? all highway, mostly highway, mostly city, ?
Offline Mml665
  • Jr. Member
  • -Given: 3
  • -Received: 1
  • Liked:
  • Likes Given: 0
« Reply #3 on: November 06, 2022, 09:11:08 AM »
22 miles round trip, I scanned it with my Autel scanner and  no injector code. How would I check for vacuum leaks?
« Last Edit: November 06, 2022, 09:14:37 AM by Mml665 »
Offline Mml665
  • Jr. Member
  • -Given: 3
  • -Received: 1
  • Liked:
  • Likes Given: 0
« Reply #4 on: November 06, 2022, 09:12:53 AM »
22 miles round trip, city driving, no extended idling. Typical Michigan ambient temps.
Offline Macgyver
  • Super Moderator
  • Eastern Pa.......
  • -Given: 100
  • -Received: 396
  • 2020 Red ST
  • Liked:
  • Likes Given: 37
« Reply #5 on: November 06, 2022, 12:46:45 PM »
I would change the plugs just because its fairly easy.
Check the tire pressure.
Change fuel brand. Use Shell if you are using Sunoco etc.
10mpg is way too low. There has to be an easy reason.
Offline Mml665
  • Jr. Member
  • -Given: 3
  • -Received: 1
  • Liked:
  • Likes Given: 0
« Reply #6 on: November 07, 2022, 09:52:18 AM »
I will change plugs soon.
