August 10, 2020, 11:40:06 AM
Author Topic: Not holding power in 1st gear in the cold?  (Read 8156 times)
Offline TopherSho
  • Eugene Oregon
  • -Given: 483
  • -Received: 372
  • 1st boosted rig!
« on: December 03, 2019, 11:23:49 AM »
I have noticed that even when driven 30 minutes the tranny is having issues holding power in 1st gear.   I am about to check the tranny oil ... but has anyone else had this occur after being 'stable' ?
Whats everyone's go to for tranny oil ? for cold weather ?
Offline FiveLeeter918
  • Ortiz Performance - Technical Sales
  • Vendor
  • Sr. Member
  • Tulsa, OK
  • -Given: 19
  • -Received: 255
  • Bewsted SHO
    • Ortiz Tuning and Performance
Re: Not holding power in 1st gear in the cold?
« Reply #1 on: December 03, 2019, 11:34:07 AM »
I run Mercon LV year round, but what are you considering "Cold" weather?
And when you say problems holding power, is TSC kicking in or it is popping out of gear?
- Lee
Offline TopherSho
  • Eugene Oregon
  • -Given: 483
  • -Received: 372
  • 1st boosted rig!
« Reply #2 on: December 03, 2019, 11:39:47 AM »
feels like it is ''low on fluid'' and letting go of the gear.  i am working so i cant check right now..  the only thing i can think of is i might have to much oil,  and it is cold enough to cause it to not flow as well as it needed this summer when it was fine.
cold btw is 22f
Offline Gjkrisa
  • Fairbanks, AK
  • -Given: 984
  • -Received: 220
    • Photos
« Reply #3 on: December 03, 2019, 11:52:33 AM »
-5 and I have started to notice in full traction off and drive it seems to shift sooner but will hold longer in sport.
I haven't looked at rpms but just by feel and sound but didn't think much of it.
Offline TopherSho
  • Eugene Oregon
  • -Given: 483
  • -Received: 372
  • 1st boosted rig!
« Reply #4 on: December 03, 2019, 02:34:13 PM »
Yeah,  The oil is the same spot on the stick,  and it is 30f warmer today and I am having no issues .. when the engine swap occurred I am willing to bet this is NOT the previous oil brand (castrol LV+) I had in the unit and it is reacting different than the Castrol did in the colder climates.
I will drop 2 cups and retest..
Offline SM105K
  • IG @egocheckersho
  • Forum Supporters
  • Arizona
  • -Given: 996
  • -Received: 1136
  • Thee Forum Cowboy
« Reply #5 on: December 03, 2019, 03:23:28 PM »
Why wasn't Ford Mercon LV put in the car?
M" 2013 SHO PP | AJPTurbo E30 Tune | FS HPFP | GH Intercooler | PPE Downpipes | Custom Magnaflow Resonator | 3rd Cat Delete | Derale Trans Cooler | Dicunzolo Gen2 Trans Mounts| EPP Noisemaker Eliminator | MSD Coil Over Plugs | SP-542's | UPR Dual Valve Catch Can | K&N Drop In | Power Stop Slotted and Drilled Rotors with Stock PP Pads | H&R Springs  | AVS Flush Deflector | Curva Concept C7's | Continental DWS06 Extreme Contact Rubber |
Offline TopherSho
  • Eugene Oregon
  • -Given: 483
  • -Received: 372
  • 1st boosted rig!
« Reply #6 on: December 03, 2019, 03:51:34 PM »
It is a guess on my part that the mechanic used some other LV+ compatible brand .. Ideally I should drop in Redline .. maybe i will spring for it this time.
  • Vendor
  • Sr. Member
  • Tulsa, OK
  • -Given: 19
  • -Received: 255
  • Bewsted SHO
« Reply #7 on: December 04, 2019, 10:29:19 AM »
be an easy and relatively inexpensive check. That's assuming they even used an LV at all.
- Lee
Offline TopherSho
  • Eugene Oregon
  • -Given: 483
  • -Received: 372
  • 1st boosted rig!
« Reply #8 on: December 05, 2019, 02:27:10 PM »
dropped half a quart out and its better,  still happens when the steering wheel is turned more than 10 degrees or so... tested with the hand held and am seeing Torque source 2 and 15.
It is frustrating a bit that in the summer i did not see this issue... I pinged BRAD / AJPturbo to see what he thinks.   in the mean time has anyone else seen colder temps trigger Torque source 2 and 15 more frequently ?
Offline SHOdded
  • Forum Supporters
  • Beltsville, MD
  • -Given: 13013
  • -Received: 4215
« Reply #9 on: December 05, 2019, 05:43:45 PM »
Hmm wonder if AdvanceTrac and EPAS are conspiring to hold you back.  Any difference in steering feel, or any pending codes?
Offline ZSHO
  • Forum Supporter
  • RotM Winner
  • New York SHO
  • -Given: 1936
  • -Received: 4071
« Reply #10 on: December 05, 2019, 06:10:46 PM »
Did you recently change the starter! I hope the dealer did not screw up with starter/Ground ..Not quite certain if its related but some ford models have intermittent Ground issues to the Trans! Dunno. Z
« Last Edit: December 05, 2019, 06:12:21 PM by ZSHO »
Offline TopherSho
  • Eugene Oregon
  • -Given: 483
  • -Received: 372
  • 1st boosted rig!
« Reply #11 on: December 06, 2019, 11:28:23 AM »
Aw man now you are taking me back to my G35 days .. I had weird shift issues after an Orsis tune+nismo cams and a head grind until I cabled the trans ground to the frame,  and cabled the two front grounds to a 8-guage wire I soldered to the the left frame and right frame ..
Naw in this case my good man it is good old 1st gear makes to much power.   Brad is going to send me a updated tune to test.
Offline ZSHO
  • Forum Supporter
  • RotM Winner
  • New York SHO
  • -Given: 1936
  • -Received: 4071
« Reply #12 on: December 06, 2019, 09:03:17 PM »
Maybe an adjustment to Torque management! Fingers crossed. Z
« Last Edit: December 06, 2019, 09:05:27 PM by ZSHO »
Offline TopherSho
  • Eugene Oregon
  • -Given: 483
  • -Received: 372
  • 1st boosted rig!
« Reply #13 on: December 09, 2019, 10:54:07 PM »
After a bump in tune revision it is much better.. still testing.  May have been old tune issues
* Recent Topics
Re: door delaminated
by jims2015 | Today at 11:04:31 AM
finally after 6.5 yrs my passenger door lining delaminated. I understa...
Re: can we add an aviator forum?
by sm105k | Today at 10:55:55 AM
posted this in New member area as well. Just found this forum.Let me g...
Re: Wheel pulls bad one way then snaps back
by sm105k | Today at 10:54:16 AM
Got it fixed for free, got to breaks plus where they had replaced the ...
by xkrexplorer | August 09, 2020, 06:14:06 PM
spent 6.5 hours putting car back to stock to sell it. Aviator gt on or...
How about adding an aviator forum
by xkrexplorer | August 09, 2020, 06:06:06 PM
got one on order, so just checking....
by bpd1151 | August 09, 2020, 04:24:21 PM
I've been hopeful for quite some time now.LOL. Pics are always po...
Re: And the award for most frequently broken car goes to...
by Macgyver | August 09, 2020, 03:38:41 PM
Lets hope their "Guy" is good....
Re: HOW-TO: Improve a bit on the X35 Phenolic Spacer
by Macgyver | August 09, 2020, 03:37:36 PM
Nice !!!Good thing its not a V12..........
Re: Info on WPC
by Macgyver | August 09, 2020, 03:34:05 PM
Very Interesting.Wonder what the Friction loss is in total if you did ...
Re: New SHO owner with problems
by ridered74 | August 09, 2020, 03:30:05 AM
Is what we are talking about....this plug and sensor?  Pics attac...
Back to top
