January 21, 2020, 01:01:54 AM
Author Topic: Could the Final Drive Ratio in 2010 Lincoln MKS really be 3.07?  (Read 119 times)
Offline Cru ss n
  • Newbie
  • Thank You
  • -Given: 0
  • -Received: 0
  • Ecobooster
« on: January 02, 2020, 08:41:12 AM »
Hello, I just purchased a 2010 Lincoln MKS Ecoboost and I noticed it shows "4A" for the axle code on the door sticker.  From my research, it appears that is a 3.07 ratio.  Could it really have a 3.07 ratio when all of the SHOs are either 2.77 or 3.16?
Thanks
Brian
« Last Edit: January 02, 2020, 09:03:45 AM by Cru ss n »
Online SHOdded
  • Administrator
  • Elite Member
  • : Beltsville, MD
  • Thank You
  • -Given: 12366
  • -Received: 4065
Re: Could the Final Drive Ratio in 2010 Lincoln MKS really be 3.07?
« Reply #1 on: January 02, 2020, 11:20:22 AM »
Did u pull the code from a truck site or vintage  site perhaps?
Offline nickstewartroc
  • Sr. Member
  • : Orlando, Florida
  • Thank You
  • -Given: 6
  • -Received: 78
  • Ecobooster
Current:
2013 Ruby Red Flex Limited EcoBoost, Unleashed Tuned, drop in filter
Gone but not forgotten: 2011 SHO Non-PP in Black Tuxedo Metallic - Catback, DPs, Stoptech Z23s, MDesign CAI, LMS Tune
Offline Cru ss n
  • Newbie
  • Thank You
  • -Given: 0
  • -Received: 0
  • Ecobooster
« Reply #3 on: January 02, 2020, 01:23:50 PM »
great, thanks.  I had seen this chart before and I assumed the 4A was the same as 4.
Axle Ratio
1 = 2.77
2 = 3.16
3 = 3.39
4 = 3.07
* Featured Topics
* Recent Topics
Re: Quality time with my Son washing the Lincoln
by SHOdded | Today at 12:52:33 AM
Very cool.  Hang in there....
Re: Blower motor removal?
by SHOdded | January 20, 2020, 07:55:57 PM
If it is anything  like the Edge, you drop the glovebox to get at...
Summit Point, WV AutoX
by StealBlueSho | January 20, 2020, 08:43:34 AM
So I was looking into having some fun at Summit Point, WV autocross ju...
Re: Wrapping intake pipe, numbers are out<<<
by 802SHO | January 20, 2020, 05:04:52 AM
Interesting. I think more tests need to be performed to give the wrap ...
by SHOdded | January 20, 2020, 03:34:05 AM
Looks great, Z!  Sorry to hear, Bronco :(...
MOVED: 2010 Taurus SHO Rack and Pinion noise
by ZSHO | January 19, 2020, 01:56:42 PM
This topic has been moved to Admin-Moderator only discussion.https://w...
Re: 2010 SHO EPAS / Rack & Pinion Noise
by 6500rpm | January 19, 2020, 11:57:28 AM
Yup, one of the boots. On a lift the suspension geometry might change ...
Re: New Bro
by PDSHO | January 18, 2020, 05:11:25 PM
Greetings from Nebraska, I think your car is the same color as mine, t...
Re: SuperPete SHO Build record
by SuperPete | January 18, 2020, 03:56:57 PM
Can you check your plugs and confirm? just a few front plugs, should b...
Re: 2013 SHO Suspension Work
by ZSHO | January 18, 2020, 12:29:41 PM
I would order new bolts and Pad rubber (anti-sqeak) for a peace of min...
wiring schematic for the sony amp in 2015 edge or flex
by Hardwired | January 18, 2020, 11:24:24 AM
I'm looking for the wiring schematic for the 3 connectors that pl...
2016 Taurus 3.5L needing timing chain & water pump replacement ... help!
by SHOdded | January 18, 2020, 09:18:45 AM
Infamous water pump leak ...Located in Racine, WI.Can anyone help perf...
Re: MKS Suspension
by TopherSho | January 17, 2020, 09:18:17 PM
Mine rides like a rock until i drop the tires to less than 32psi, ...
Re: DannyMack 13 MKS "Old Man" Build and Maintenance Thread
by Dannymack | January 17, 2020, 02:22:58 PM
Finished up the rack today and added the bike racks. Wouldn't be ...
Re: 2014 Lincoln MKS EcoBoost with all the goodies
by Agentlongwood | January 17, 2020, 10:58:54 AM
Everybody I've interacted with on this forum has always been supe...
Back to top
