Quote from: AJP turbo on January 12, 2017, 09:27:48 PM
And stealblue when you said my tune had boost spike in 1st gear when I was at 201 kpa desired is that when I had the throttle open and you were playing doctor boost controller LOL?...I think I wanted the gate to open and you wanted to delay the opening which allowed for a bit more spike which was ok because you had fuel pressure.
The throttle closures are awesome at mitigating boost spikes.
And there is a pretty big difference between 201 kpa and 186kpa....If I tune people at less than 185 ish I could keep the throttle open as boost spikes probably wouldn't go over about 215 is on the 2-3 shift.....But when I get into the 190 ish kpa then I need to use the throttle because boost spikes would exceed 220 kpa on the 2-3 shift and fuel pressure plummets and I'd rather not see that happen.
Hmmm negative, I wasn't referencing the wastegate mod.. the difference in the first gear spike is noted here... here is the log when you were tuning my car and the desired TIP was 199... notice the difference in the boost curve in first gear.. yes, your tune is running more boost by 13kpa.. however, that spike in first is what i would expect to see... in LMS that does not exist... both tunes are using the throttle to control spikes.
IN ANY EVENT... regardless of boost spikes which is has been beat to death...
The reason for the spike vs boost question is simply this....
If I am at the track, and my WGDC is sitting at 80% throughout the entire run my IAT's are going to climb yes? More so than if it was sitting at 60%?
IIRC the ecu scales back spark as the IAT's climbs?
So.. if I am running a tune that is originally targeting 20 degress of spark, but because my wastegate is running at 80% my IAT's climb, which by the time I am in 3rd gear, the ECU would scaling back on spark to 15 degress due to hotter air at the sensors which in effect would cause me to loose power?
If I am running a tune that is originally targeting 20 degress of spark, but my wastegate is running at 60% so my IAT's are not as hot, so when I am in 3rd gear, the ECU wouldn't scale the spark back as much if at all so I am still sitting at 20 degress of spark.. however, my boost will be lower but I maintain higher spark throughout the entire run...
So at which point is the breaking point? is 5 degrees of spark worth 1psi or so?
or am I looking at this all wrong?
