Like I said, once I get my times nailed down on current setup so I can apples to apples my time to the dyno numbers, I will work on checking a few other wastegate settings (it will be warmer so I can go higher on the spring).
I am running between 15 and 16psi now, with 20 degrees spark, after I know what I can do on these settings with my springs, I'll go down in boost, up in spark a bit for the track. If I get lucky and end up at a test and tune like the last one, where I can get 20 runs in the night, I can get a whole lotta comparison.
Of course doing so will require Brad to be patient with me, or us to make some arbitrary combinations/boost and spark desires, and then run the tunes. Will probably be march or april before tracks open and I am able, but I think it would be nice to see.
