Ecoboost Performance
Troubleshooting, Maintenance, TSB Articles
Troubleshooting
3-4 shift on light throttle went to neutral
Started by Gray Brick, June 20, 2016, 10:01:49 AM
Gray Brick
Sr. Member
Gray Brick
During light city driving my Flex attempted to go into fourth gear and just reved.
I let off the gas and it calmly went into gear.
This happened 3 times... a bit concerned.
I disconnected the +battery post and grounded it over night to reset comuter.
Has not happened again but the shifts are a little harsh on light throttle.
Any ideas on what is happening?
2013 Ecoboost Ford Flex
Forum Supporters
Re: 3-4 shift on light throttle went to neutral
June 20, 2016, 01:08:14 PM
No codes? When was the last time you changed spark plugs/transmission fluid etc.? Datalogged recently?
Gray Brick
Sr. Member
Gray Brick
June 20, 2016, 03:55:50 PM
No codes, plugs 5k ago, drain and fill trans 8k ago.
Nothing strange in the datalogs that I can see.
Do you have anything to look for other than line pressure?
Troubleshooting
