Hesitation and high KR Cold weather issues?
Started by ShoBoat, April 05, 2015, 12:19:47 PM
Manu, are you thinking along the lines of what happened with BigMac?
Rich
Exactly right, Rich, though I don't have a way to justify it yet.  If FRP is being commanded, why is it not being delivered?  Is it a logic problem, a voltage problem, or a mechanical problem?  Puzzling.
ShoBoat
Quote from: SHOdded on April 25, 2015, 08:47:34 AM
Exactly right, Rich, though I don't have a way to justify it yet.  If FRP is being commanded, why is it not being delivered?  Is it as logic problem, a voltage problem, or a mechanical problem?  Puzzling.
I guess I can try against stock again and go from there. I was assuming it was tune + 94 winter gas.
2012 Pearl White CTS-V Stock
ShoBoat
What is the known 55 mph issue?
Think Manu was referencing your post about it being at 55 mph.
BigMac had a fuel delivery issue stemming from the tank pump that would sporadically pop up.
Rich
Quote from: ShoBoat on April 25, 2015, 08:54:40 AM
No known issue, I was referring to the conditions under which you are seeing the problems in your latest test :)
ShoBoat
Ok a quick (chappy lol) chart of the HP VS the LP fuel delivery on the failed run. To me the LP side looks ok, it drops slightly to 98 PSI from the commanded 102 PSI and on the successful (no hesitation roll from 30 mph) the same LPF is pretty solid dropping slightly to 98 also.
I going to try a stock run to see if the FRP drops from a 55mph roll.
Quote from: SHOnUup on April 25, 2015, 09:03:12 AM
Rich
Yea... Had a comm code about fuel delivery module communication with PCM and DTC with CEL for low fuel rail pressure... On the way to the dealer She died.... The low pressure fuel pump had failed and replacement didn't fix it... They died at a stoplight in the test drive... So the fuel control module was replaced and no problems since.  BTW... The car actually runs better than ever... I believe function on these components can decline significantly before setting a DTC.  Mine happened at initial startup and for a while the car went into  limp mode. The problem I had was never a high speed (above 30 mph) thing.
So consider the FCM as well as the fuel pumps... And communication.
ecoboostsho
Curious if your throttle plate is closing when you lose fuel pressure? I believe you can log it and it would be interesting to see what it is doing while you have it "floored".
ShoBoat
Quote from: ecoboostsho on April 25, 2015, 09:21:01 AM
sometimes yes it closes briefly then it's wide open. Others it stays wide open during the issue.
Did you ever check for any exhaust leaks,an exhaust leak on the left bank will cause lean and rich conditions beyond what the PCM can control with fueling,the exhaust leak will make the engine run lean above idle speed and run rich at an idle on that bank.Z
ShoBoat
Quote from: ZSHO on April 25, 2015, 10:19:19 AM
Yes I did, actually thats how I found out that the PTU was leaking. It's fine at idle. Bank 1 and 2 are perfectly in sync. I just came back from a data run on the stock tune and no issues at all. I will post the logs in a few min.
Quote from: ShoBoat on April 25, 2015, 08:24:17 AM
Quote from: FoMoCoSHO on April 25, 2015, 02:06:37 AM
Red commanded, blue actual?
bank 1 and 2
Is it commanding 10.4 AFR?
I wish shipping to Canada wasn't stupid, I won't need my x4 for a few months
ShoBoat
#179
Ok this time we have the actual screen shots from Forscan, hopefully a bit easier to read. The interesting thing to look at is the throttle plate position in the stock and tuned runs. Then the 30 mph WOT run. I am a little confused on why from the 50 mph roll it falls flat on it's face. To me this looks like a tuning issue. Any thoughts? Also the 2nd 50MPH run it recovered??
FoMo Sorry I did not have the commanded AFR on the last set of runs. But when I did in the past it was really close to the commanded value.
