A typical summer-grade gasoline is composed of fluid catalytic cracker gasoline, 40%; straight-run gasoline (directly from crude oil distillation), 25%; alkylate, 15%; reformate, 18%; and butane, 2%. Winter-grade gasoline usually contains more butane, which has an octane rating slightly below premium gasoline (91-93 octane). While butane is an economic component of gasoline, the high volatility of butane limits the amount of butane that can be used in summer-grade gasoline.
Just a FYI for those of you with issues like mine and higher KR than normal in winter.
