Yet another failure
Started by polskifacet, July 12, 2019, 10:33:46 AM
SM105K
Quote from: 802SHO on July 16, 2019, 10:33:59 AM
Quote from: SM105K on July 16, 2019, 10:27:08 AM
Quote from: 802SHO on July 16, 2019, 09:48:09 AM
Fingers crossed its just the mounts and you're paranoid
For the first 200 miles with the new mounts I was on extreme edge.  My car never made the sounds, vibrations, or direct driver inputs until I put the mounts in.
That being said, I love the DAMN things.  The shifts are amazing, the driver inputs are magnified, and the sound!  Inside the cabin the car actually sounds like it has an exhaust now.  The pitch and feeling of the motor has completely changed for the better for me.  Now other people may absolutely hate it, but not I.
I concur, I love them too!  Could never live without now.  Tim said he started hearing a sound after the mounts so I hope it's just associated with the mounts and not his PTU or Rear Dif.  Another thing to try maybe would be to put the stock mounts back in and see if the noise goes away.
I actually laughed when how easy it was to swap them.  Nothing ever goes that easy.  Directly after installing them, I was rolling out from under the car..and was thinking EFFING Andrew and his peer pressure.
802SHO
Lolol I'll be the guy saying "do it" then turn it on me..."I'm not doing that" I'll say!  And thanks...of course I was under the car for longer than I'd admit...of course with ADHD anything shiny grabs my attention so I'm not sure how focused I was while looking over everything else I could see....i wasnt laughing though...I was like...how am I supposed to?
shoNoff
You 2 clowns kill me lol. I'm off tomorrow so I'm gonna swap the mounts back for the hell of it. Also I put 2 rear tires on since the noise started. I'm gonna swap them to the front. My dad road with me this morning told me I'm insane his mustang makes the same sound.
2013 SHO PP 12.51 @ 110.07 AJP tuned sold
2016 edge sport 13.92 @ 99.4 mph. slow and stock baby mobile
SM105K
Quote from: shoNoff on July 16, 2019, 11:02:31 AM
Good, get to work!  LoL.
shoNoff
Quote from: SM105K on July 16, 2019, 11:12:37 AM
Andrew can confirm this. I was tearing all my parts out and selling the b*tch as of yesterday lol.
802SHO
Quote from: shoNoff on July 16, 2019, 11:25:28 AM
It's true...he was so mad he was looking at a Hyundai.....lol JK!
shoNoff
Quote from: 802SHO on July 16, 2019, 11:57:55 AM
What you didn't like that accent GT?
polskifacet
Anyone have any idea how to know what the ratio is of the 100s of junkyard diffs available. Most of them just say SHO but don't specify 2.77 vs 3.16
Black Dream
Quote from: polskifacet on July 12, 2019, 04:49:12 PM
I'm doing the retract when you put into reverse delete as even when its down it tries to retract causing the gear teeth to sheer off.
Would you care to share how to do this?  I don't have any issues with the shade ATM but use the function every day and I can only assume with a 10 year old, 100K mile car that issues might start showing their face sooner than later.
2010 MKS Eco, Airaid, SCT X4, Unleashed, SP542 plugs, 3 bar MAP and current daily.
2006 Pontiac GTO M6, 1 of 101 exactly like her, bone stock, lost to flood 5/19, gone but not forgotten....
Black Dream
After a little research I found an answer, not sure this is the easiest way but it'll work.  Removing the rear parcel shelf will give us access to the rear shade motor.  Disconnect it and voila, no power to the shade.  Here's a link to a page with the FSM diagrams to help in the removal for my MKS.  I would assume SHO procedure would be similar.  https://www.justanswer.com/ford-lincoln/8a7h0-lincoln-mks-2010-lincoln-mks-rear-sun-shade.html
polskifacet
If anyone has access the ford system/vin lookup, would like to verify gear ratio for 1fahp2kt3bg128217. I think ZSHO would be my best bet.
4sfed
...Inside the cabin the car actually sounds like it has an exhaust now.  The pitch and feeling of the motor has completely changed for the better for me.  Now other people may absolutely hate it, but not I.
Funny you mention that.  I noted in my original post after installing these that it sounds like a Mustang with a quiet Magnaflow system inside the car, but outside audibly, nothing's changed!
2015 SHO, GH E30 tune, GH intercooler, 3 bar, SP542's, PPE Cat'd DP's, XDI-35, H&R springs, AD Gen2 mounts
Factory Five Mark III, 2004 Mach I donor (gone)
2003 Mustang Cobra 'vert, 456 rwhp, with mods (gone)
2002 MB C32 AMG (gone)
1997 Cobra 'vert, Vortech'd (gone)
SM105K
Quote from: 4sfed on July 18, 2019, 01:33:57 PM
You literally just nailed in words what I hear now.  Wonder how much it will change when the DP's go on.
shoNoff
Quote from: SM105K on July 18, 2019, 01:56:08 PM
I've only had mine in with the downpipes. I can say outside the car is legit no difference with or without pipes. Cold start is the only noticeable difference. That and the slight turbo whine when accelerating.
