Brake lights staying on sometimes
Started by Frozen Taurus, June 07, 2016, 04:37:41 PM
Frozen Taurus
Anytime I park facing downhill there's a good chance that with just the weight of the brake pedal on the brake switch my brake lights stay on ....
Is there a way to adjust this? It does it so randomly and sometimes on it's own after I have parked it and gone inside. This morning my wife came outside and found them on ... who knows how long they were like that....fml
Blackhawk
Your switch is probably going bad and sticking. do you ever feel your car hesitate when trying to accelerate at cruising speed?
Any other issues with the brake system?  Sponginess or hard pedal or ...  On the Gen 4.1s, the booster would become weak over time, ultimately causing the master cylinder to weaken as well.  Any DTCs in the PCM?
Frozen Taurus
Quote from: Blackhawk on June 07, 2016, 05:05:44 PM
No it runs fine
Frozen Taurus
Quote from: SHOdded on June 08, 2016, 06:58:25 AM
I've always thought the brake pedal was spongy right from the day I bought it. I've since upgraded the brakes and lines and although it did improve a bit it's still not as firm as it should be
No codes at all
scoles92
My brake lights would stay on sometimes. replaced the brake switch and haven't had a problem since. the ford stealership wanted to charge me around $300 i think haha takes 5 mins to install and the part was 28 or so on rock auto when i did mine last year. literally takes more time to get down there and get in a comfortable position than to change the part.
2011 ford Taurus SHO PP  unleashed tunes, 3 bar, plugs,K&N intake, stage 3 water meth.
Blackhawk
Same thing for me on my 2011
Quote from: scoles92 on June 08, 2016, 04:05:53 PM
scoles92
Frozen Taurus
This will probably be the route I take too then .... it makes most sense.
