April 1st, 2015 - I received the "MyCal" Device and submitted a tuning request.
April 2nd 2015 - I received the tune files.
April 7th, 2015 - Installed the plugs, t-stat, 3bar, and tune. Send an email to Livernois and reported that my shifts were too hard to go to WOT.
April 22nd, 2015 - Installed the intake and ran dyno runs.
May 11th, 2015 - Had the downpipes and catback exhaust installed. Tried to get the updated tuner files, and received an error message "Updates required to load tune file".
May 12th, 2015 - Reported to Livernois that I was having sputter and a loss of power at WOT. I also sent them a video....Livernois told me to try the 91 Tune.
http://youtu.be/1R9hZfDm1w4 May 13th, 2015 - I told Livernois that the sputter is worse with the 91 tune and I went back to the 93 octane.
May 18th, 2015 - Received another tune update from Livernois. Tried to flash and got an error message "An Error has occurred. Please write down the following error message then call tech support. 7e"
May 19th, 2015 - Received ANOTHER tune update from livernois to try to get the tuner to work properly.
May 20th, 2015 - Removed the catless downpipes and updated the tune without the O2 delete. The tune would not take in my car and after multiple attempts, I was able to get the car back to stock. Determined that the tuner was bad. Livernois sent a replacement tuner unit.
June 19th, 2015 - Reported sputtering at idle. (no response)
June 19th, 2015 - Recorded video of my exhaust popping at WOT (I didn't post the video until October (but was recorded part of Rasp from hell part 2 series)
https://www.youtube.com/watch?v=aQLhUO-8NiAJune 25th, 2015 - Reported sputtering at idle again and mentioned that I could have someone data log for me.
June 25th, 2015 - Livernois responded stating exactly: "You can send us the data logs if you would like. Primarily data logging is used for wide open throttle situations so I cannot say that it would show us much."
... after 3 months of back and forth I dropped the subject..
Then in October I was getting frustrated with my sputter again and I posted a video of the sputtering. I've received about 10 different comments on a variety of my videos about similar issues...
You get my point....
And yes, I still have sputter. And yes it only happens at WOT. And yes, Livernois even said in an email "Primarily data logging is used for wide open throttle situations".
I'm sorry that you feel that I'm not following your instructions. I'm going to change the plugs and move forward from there.
