High pressure A/C switch?
Started by Three Lions, June 29, 2015, 12:04:59 PM
Three Lions
Need a little help.
I have been suffering with lackluster a/c performance this year. The air blows cool but not ice cold like it should. In addition to this my engine fans run as soon as I start the vehicle regardless of exterior temperature, they were also doing this in the winter/spring.
After doing a little research, I'm thinking possibly the high pressure A/C switch. What do you guys think?
Thanks, Andrew.
2011 Taurus SHO PP
3BAR MAP, Unleashed 3BAR tune, 170 Reische T-stat, K&N Panel Filter & SP534's gapped 0.30
SHO Fender badges, SEL Taillights, 2 x Kicker CVX 12" subs in custom box. Pioneer 1 Ohm Mono Amp. Hard wired Escort Passport X50 w/ Mirror Mount.
Andrew do you hear the compressor engaging,any clicking when a/c is on? hows the coolant level,and possibly your stat could be stuck,causing the fans to come on rapidly,hows your temp gauge,is it normal.BTW you could purchase a gauge and check your freon levels on the low pressure side. Z
Three Lions
compressor engages fine, no clicking and checked coolant last night and it appeared to be at the required level. Temp gauge usually sits at the mid-point regardless of exterior temps.
2011 Taurus SHO PP
Quote from: Three Lions on June 29, 2015, 01:55:31 PM
I personally think its not your high pressure switch,if the switch was bad you would hear it clicking,and also when your freon levels are very low,you could be just a little low on freon considering the air is cool. Z
