Transmission slipping? Upgrade? Ideas needed...
Started by Grimster, April 24, 2014, 06:42:18 PM
Gray Brick
I had the same problem... I was running too much w/m.  It was quenching.
I went to a smaller nozzle and it went away and picked up tons of HP as well.
2013 Ecoboost Ford Flex
AJP Tune (ATP+2) in progress , Livernois HPFP, 3 Bar MAP, UPR Catch Can, 100% Methanol w/ braided steel lines, 3" Downpipes -->2.5" X-pipe --> 2.5" Magnaflow exhaust, 2.5" air inlets to each turbo with cone filter, Custom water to air intercooler with chiller
275/40-20 Front 315/35-20 Rear Tires
---12.419ET/112.43MPH @ 5150 lbs in the 1/4---
14SHOCAR
I had the same problem and the issue had to do with the vacuum lines. Check out my video.
https://www.youtube.com/watch?v=vrhBu5XtafU
14 Taurus SHO (Sold)
