Torque coolant temp
Started by jtoddk98, June 01, 2015, 03:25:54 PM
jtoddk98
The coolant temp gauge on torque has recently stopped working. Every once in a while it will update, but it isn't instantaneous like all the others, it was working fine just the other day. Is it my adapter? I've tried to restart the phone, repair the adapter, still doesn't work
Could be the adapter if it is a generic ELM adapter and you have a long list of parameters you are monitoring simultaneously.  What is your setup?
Have you tried deleting the gauge from your current setup then adding it back?
2010 RCM non PP
K&N panel filter with aux hose
RX OCC with CSS
sp534 @ 30
unleashed tune 12.90@106
jtoddk98
I've tried re-adding it and deleted some gauges to relieve some stress on the adapter. Still doesn't work. It updates periodically. I have a generic elm adapter but it has worked flawlessly for the past year, the coolant temp just stopped working yesterday.
Have you tried removing the ELM adapter, giving it about 30 seconds, then reinserting into the OBD socket?  Usually I do this when I have pairing issues between the adapter and Torque Pro.  No data collection issues yet in the last year with OBDLink MX (bluetooth), monitoring almost 30 parameters.
Unlikely that the car's sensor is actually faulty, but someone has to have that happen first!
Does your gauge on the OEM cluster still work?
Gray Brick
I have the exact same issue.
I usually exit Torque and when I go back in it works for a little while.
2013 Ecoboost Ford Flex
AJP Tune (ATP+2) in progress , Livernois HPFP, 3 Bar MAP, UPR Catch Can, 100% Methanol w/ braided steel lines, 3" Downpipes -->2.5" X-pipe --> 2.5" Magnaflow exhaust, 2.5" air inlets to each turbo with cone filter, Custom water to air intercooler with chiller
275/40-20 Front 315/35-20 Rear Tires
---12.419ET/112.43MPH @ 5150 lbs in the 1/4---
jtoddk98
Quote from: FoMoCoSHO on June 02, 2015, 09:10:08 AM
yes it does.
Quote from: jtoddk98 on June 02, 2015, 10:38:08 PM
yes it does.
My guess is the issue lies with Torque or the adapter.
My money is on the adapter.....have you examined the contacts for any kind of corrosion?
