Quote from: IHeartGroceries on March 08, 2015, 12:26:47 PM
I'm slightly confused on how one member here has been successful building an 800 horsepower beast utilizing OE.
Whereas 4DR maxed out well before that and had to resort to PI.
1st, there's no need to supplement, or replace/upgrade the LPFP. On my various dyno runs and resulting tune files (DD 400awhp, Stage 1 Track 525awhp, Stage 2 track 617awhp) there was only a scant 1psi drop on the LPFP side across the board.
So that in and of itself, assures me, that the OEM LPFP is perfectly capable.
It was explained to me, that running a completely separate set of injectors, essentially taxes the crap out of the OEM LPFP, and likely why someone was experiencing repeated shutdown of the TB, etc. and required the additional pumps, controls, etc.
I've said it time and time again, it's not necessary to run a separate set of injectors.Factor in the use of E85 (
which I'm not a well known fan of, for a myriad of reasons) it takes a
LOT more E, to burn the equivalent of the 93 Pump Gas (or even the 109 Race Gas for the higher tune files).
Moving along, we did see drops on the HPFP side. Which, on it's floor (or lowest end) ranged in the 900-1000psi range(s) respectively. Previous info posted here is accurate in that the desired target range is 2000-2200psi range(s) ideally.
This is where the 100% Methanol factors in.It was suggested I ramp up to a dual nozzle meth setup in order to reacquire the targeted HPFP range(s).
I did so, and well...... you the see the results.
That's how I am able to "pull off" what I have by completely retaining
EVERY ASPECT of the OEM Fueling System.
We all have similar goals in mind as far as desiring to achieve the most power, etc. out of our respective setups.
How we achieve those goals though, will obviously be different.
Some of those differences I have learned over the years, is that 93 Pump Gas is not readily available in all areas of the Country. I'm glad that it is in my area.
It goes w/o saying that others may have to embrace other alternatives/solutions that wouldn't necessarily be in line with my levels of acceptance.
Doesn't mean one is wrong, or one is right. It's just a different means to a different end.
We should all be thankful for all of those who've been involved over the years for their poise, sense of direction, willingness to test, and push the Ecoboost platform in the manner(s) that they have.....
EVERYONE.
Ultimately, the results achieved on my SHO speak for themselves.
