Ecoboost Performance
Troubleshooting, Maintenance, TSB Articles
Troubleshooting
High Intake Temps - How to remedy???
Started by Gray Brick, December 18, 2014, 01:31:00 PM
Gray Brick
Sr. Member
Gray Brick
Has anyone sealed the factory airbox to remove some of the incoming engine heat?
Any recommendations on how to bring this temp down?
Attached picture shows Flex sitting and idling for 15 minutes.
Almost a 30 degree differential between ambient and intake temp at the airbox.
2013 Ecoboost Ford Flex
AJP Tune (ATP+2) in progress , Livernois HPFP, 3 Bar MAP, UPR Catch Can, 100% Methanol w/ braided steel lines, 3" Downpipes -->2.5" X-pipe --> 2.5" Magnaflow exhaust, 2.5" air inlets to each turbo with cone filter, Custom water to air intercooler with chiller
275/40-20 Front 315/35-20 Rear Tires
---12.419ET/112.43MPH @ 5150 lbs in the 1/4---
Super Moderator
The Tenth Man
Re: High Intake Temps - How to remedy???
December 18, 2014, 02:52:58 PM
Do your iat2 temps plummet when spraying?
Gray Brick
Sr. Member
Gray Brick
December 18, 2014, 03:15:08 PM
They go down but start rising....
I am slowly adding more W/M to see if I can get them lower.
91hybrid
Full Member
Ecobooster
December 19, 2014, 12:20:59 AM
Have you logged your iat2 temp? That's what I log. And yes mine drops substantially at first and the starts to rise again after about 2nd or 3rd gear.
Most folks have their initial at 8 psi and full in by 10 - 12 psi.
At 18 full your only full meth for a fraction of a second at your boost spikes.
John
2014 SHO -PP, Unleashed Tuned, 3bar, Devils Own 100% meth, PPE catted down pipes, 3rd cat delete, Magnaflow 2.5" exhaust, 170 deg, NGK 7's plugs, hot pipes - White Platinum 401a
418 whp - 513 wlb/ft
non meth 13.11@103.6 (knock limited)
Meth pass 11.991@114.28
Super Moderator
The Tenth Man
#4
December 19, 2014, 09:16:35 AM
In torque IAT2 and cac are different sensors, you might see if iat2 is a listed pid and log that also.
Forum Supporter!
RotM Winner
Ecobooster
#5
December 20, 2014, 12:24:17 AM
Last Edit
: December 20, 2014, 12:25:59 AM by BiGMaC
Go look at the Zero2Sixty Motorsports Facebook page... New IC development for '10+ SHO.... Early yet, but good pics. Nothing on the Website yet, just FB.
Gray Brick
Sr. Member
Gray Brick
December 21, 2014, 04:18:39 PM
Good info
Troubleshooting
