launching the X
Started by explorergotoluvit, May 15, 2014, 10:47:26 AM
explorergotoluvit
Quote from: bigmoneycloser on May 15, 2014, 03:05:36 PM
I have done a few launches braking up to 2k rpm then gooooo... Only with TC off. With no issues.
I didn't notice any rpm limits either, but I was trying to stay at or under 2k...
The TC will shut you down if it don't like what your doing...
yes around 2K RPM launch are pretty damn good I agree
2013 explorer sport
LMS tuner stat 160 3 bar magna flow v8 91 map
k&n H&R spring
retrofit FXR bi-xenon projectors done by lightwerkz
all lights replaced with leds from daytimebrightlites
Is your friend's wrx stock or tuned?  That may be a good feature to implement in our cars as well, and probably could be done by the tuner.  May be a bit more complicated than on the wrx.  Isn't the wrx fulltime awd?
Josephm
Quote from: Josephm on May 15, 2014, 01:17:40 PM
It goes into protection and cuts all power. Its because your front tires are spinning faster than the rears. Mine has done it a few times at the track
12' Flex EB
Unleashed X4
3rd Cat delete
Courier6
I played around with RPM on launches a lot at the strip, best times were achieved around 2K RPM, that was the sweet spot on my 2011 and 2013 SHO's.
2013 Tri-White PP, PPE downpipes, Corsa, Air Raid CAI, H&R Springs, 170 deg thermo, Livernois Dyno Tune 365 AWHP 407 AWTQ. Best 1/4 mile 12.580
MDesign Performance
Quote from: Courier6 on May 15, 2014, 08:59:16 PM
I concur on my 2011.
2011 MKS EcoBoost: MDesign Carbon Cold Air Intake; SP-534 Plugs; Power Stop C/S Rotors
sales@mdesignperformance.com
www.mdesignperformance.com
www.facebook.com/MDesignPerformance
explorergotoluvit
Quote from: SHOdded on May 15, 2014, 03:42:46 PM
wrx was tune but by us so nothing was tuned for that kinda of stuff and it did it when it was stock as well
2013 explorer sport
k&n H&R spring
curry67
Ive been launching at 1500 and trying to do it in like one motion without rpm bobbing.  I noticed when I went to high it felt like less accel. 0 to 40. No times though just feel :)
Sent from my SGH-I337M using Tapatalk
My best time was had with a 1500 RPM launch...
QuickSilver
Click the selector dial into 'sand mode' (the one with the cactus image) power brake it to about 1900 and try it again...
AJ
2014 Ingot Silver Explorer Sport- LMS V3 Tune, AirRaid CAI, Hi_flow Catted DP's to Complete dual 2.5" exhaust, 19"X 9.5"TSW Panorama Rotary Forged/powdercoated Rims, Cree LED Foglights, Hoping for those Megan coilovers to be developed...
Airbornemaikai
I know this is a couple months old now, but I also found about 2k to be the sweet spot. Seems like anything over than this and the tires seem to break loose anyway (tested with brand new Spec-x's also)
2014 Explorer Sport
LMS 91 Tune with 3 Bar Map
160ยบ Evenflo T-stat, 0.30 Motorcraft plugs
LMS DP W/HI-Flow Cats, LMS Corsa Cat-Back
Airaid 401-260
jzales
Quote from: Airbornemaikai on September 02, 2014, 08:23:44 PM
2k in normal mode, Tc off has netted me the best times.. I always leave the shifter in "D" will leaving it in "M" change anything?
black99lightning
Quote from: jzales on October 09, 2014, 12:11:02 PM
Pretty sure in M you have to use the paddles.  We're not going to outshift the auto.
2013 Esport 13.44 @ 103.6
1999 Lightning 12.44 @ 108.4
2012 GT500 10.96 @ 130.6
2006 GTO 12.83 @ 107.8
2013 CTSV coupe 11.79 @ 119.7
black99lightning
Also anything definitive between launching in sand vs. normal with TC off?  Seems to be a little more spirited in sand?
jzales
Quote from: black99lightning on October 09, 2014, 03:04:31 PM
Not on my 14 you do not.  If you floor it in M it will shift at redline.. I'm not trying out outshift the auto, rather I want to shift at redline not earlier.
curry67
ive always thought about what is the procedure for a perfect launch ive heard auto and launching at 1800-2500 is best. i do like feeling in M.
